Alternator installation
Started by Wasim, August 30, 2015, 05:59:52 PM
Wasim
G'Day,
          Is there any link to a post on the forum on how to replace the generator with an alternator including brackets and wiring?
Thanks, Wasim
South Australia
collecta
 Hi Tony, my Ute runs an alternator your welcome to have a look at the (grey motor)conversion.
Scott
Crumpsnr
Hi Wasim,
I have a primitive drawing that I could jazz up a bit showing all connections. I'm no electrician so the drawing is pretty basic and designed so I could follow it years later! I'll track it down and get back to you. I can recall it's for an external regulator setup.
Regards,
Martyn
Crumpsnr
Hi Wasim, these are pretty rough drawings I did about 25 years ago. Looks like I had 2 different types of alternators. No doubt some here will be able to make sense of what I did. I had no idea but they worked! Now that I look at them they seem less about a conversion than just a setup for red motor electrics. Not really sure if this will help but better i put them up and let you decide. Regards, Martyn
This is a diagram I put together many years ago
Wasim
Thanks for the replies everyone.
I found this bracket on the web - looks OK - gives me the idea of what I need to do?
Regards, Wasim
South Australia
