fc ute @lone star body shop
Started by waynos, May 03, 2015, 02:33:24 PM
waynos
waynos
 fink.
its gonna be pretty stock but we are a hotrod shop after all so we cant help ourselves modifying stuff if the customer allows it.
waynos
firekraka,
we are located just south of sydney near helensburgh at darkes forest.thanks mate i will try to keep the photos comin
waynos
i rarely take photos at work, but cause ive got an fc i thought i better show you guys this stuff.its hard to get good pics like you would at home cause you are always busting your arse to get stuff done cause the customer is paying and you all know it takes way longer than ya think .no time for photos .......gotta get it done
waynos
#25
hsv 001
this aint an ad
i just work there and know how good it is to see build pics of any car,
hope people enjoy it
Not Happy Jan
Good Job Waynos
Keep the photos coming. Nothing wrong with that!
You can never have too many!
Port Macquarie NSW
waynos
waynos
fink
Nice work buddy,i'm assuming it's tig welded,good news now that Bunnings has oxy etc now,hey!
waynos
Here's the left hand side
Fink,those bottles at bunnings are really expensive.they run out real quick.we have a place called gasweld in nsw. You buy. An E. Size bottle and they fill it when ya run out with no rental.there must be somewhere in Vic that does the same.
waynos
Glen's doin an awesome job repairing the Swiss cheese on the subframe
Everyone loves sparks and welding pics right?
waynos
59wagon
Quote from: waynos on June 19, 2015, 10:59:52 PM
Looking good and appreciate the updates. When welding on the sub frame, do you need to do anything to prevent possible heat distortion / twisting?
Cheers, John
waynos
glen is doing small patches ,one at a time so no need to worry about bracing it to prevent twisting.
if you were cutting and rebuilding the alot at once  i would weld or bolt some bracing to the mounting points and keep it on flat ground as i welded and try to weld things opposing each other so it pulls equally,
hope that makes sense
59wagon
waynos
waynos
This patch had a slight chance of twisting,so a brace was used,but considering it was tig welded and also spot welded, there would be minimal heat transfer,thus no real distortion of the subframe anyway
waynos
Some inexperienced welders can go to extreme lengths to brace everything, but do not know the effects of the heat they are putting into the piece,and it will warp and move a whole lot more than someone that knows what they are doin with minimal bracing in the right places, where they know it will pull or distort
waynos
