Rocker shaft
Started by Fraze, November 26, 2014, 01:06:40 PM
Fraze
today I bought the last grey motor rocker shaft in stock at Auto Surplus. NOW _ where do I get a second shaft to make the pair????? Can anyone point me in the right direction? Thanks, Frazer
There's a few in Melbourne u might be interested in on eBay.
This guy has a heap of miscellaneous parts
And this complete head in Nsw. But sometimes it's worth talking to them to see if they have other stuff.
slim
LOL. I have other stuff. Just a bit ,,  ;D ;D
Im located at Liverpool, NSW
I think Fraser is wanting a new one......
He can buy 2 used one's, then he will have a spare 😆
Fraze
I have several used rocker shafts and only one new one so I would really like a mate for it - any clues out there on where to try for another new one??????Thanks, Frazer
I did check some places and no luck sorry. Have you tried these guys who specialise in grey motor era cars. They will know if there are any.
Fraze
Thanks for the clue Deano, I called Old Oldens but they only had used rocker shafts. I will keep searching for a new one - there has to be one somewhere - just a matter of wrinkling it out. Cheers, Frazer
Yeah I reckon. Some of the Facebook groups have wanted sections in large cities. Might be worth a try.
GreyFC
Malcom Church makes them.  As good as brand new if not better but they're not cheap I think it's $600 a set.
Fraze
If I can't get a new rocker shaft I will look at turning the existing ones (which aren't too bad) through 90 deg. to the unworn area. Frazer
Fraze
Can't rotate the rocker shaft 90 deg!!!! Oil hole has to line up.
If the old one isn't too bad, can you copper plate til right thickness.
Fraze
I had the original rocker shafts linished this arvo and they are pretty good so I will go with them until I can find a new one. Frazer
I'm a bit surprised you can't get new ones. Are these an item that wear out a lot or only on high km motors? Does anyone know.
They do wear and it is hard to find a shaft without some evidence of abrasion. Typically it doesn't effect the engine very much though, so most people don't bother replacing them. Even very worn shafts will still run ok.
I wouldn't have thought it would matter much, but I'll will be interested to see how much wear the taxi shafts have. Thanks Ken.
