FC Ute
Started by FCRB26, February 12, 2013, 01:49:00 PM
Pete the exhaust looks great like the other guys I am not a fan of the headers going through the inner guards.
I just had a look at the Summit handbrake setup as well it looks really good and as you said simple to fit I think I will use it on my next project.
Neil H
Big day
Tubbs all welded up
Cut all the old stuff out .
welded edge of rail where I cut flange off.
Using existing outer guard and lip just cut 20mm off the lip joint.
Hopefully install both tommorow.
Photo's tomorrow will be worth it. Great stuff.
Wayne b
Hopefully if my helper turns up on time.
FATBOY
nice work pete
regards fatboy
fatboy
0414712441
My helper was late. So I only got 1 side almost finished.
Other side is cut out and prepped for tub.
Took 2 hrs of snipping and trimming to get it to fit spot on.
Rhs fully welded in.
Only have a half done photo its too hot and im to lazy to go back over to the shed.
The inner overlaps rail 20mm and is plug welded hence the grinding marks.
FATBOY
Looks sweet hope you took a template
regards fatboy
fatboy
0414712441
A template
I made 500 measurements and cuts used clecos to hold them in.
What a shitty job especially since the cars loaded with fishoil shit was running everywhere.
So no template :D
Very nice  ;D ;D ;D ;D will 265 fit under the back  ??? ???......FC427.........
FCV08
Looks fantastic  ;D ;D
Good to see your progressing with your own project(s)  ;)
Craig
ill stick to 245,s for the moment.
I wish the wife was as enthusiastic about my projects.
Ah look what arrived today.
Subframe is mint front bar is mint
Grille is in good nick
Sills are good inners ok gearbox crossmember excellent.
Rear half is ordinary under the car like half been hanging out in the grass.
Some good parts anyway. Best 500 bucks I ever spent
Are you going to part out the ute  ??? ??? ??? ???.....FC427.......
Probablly what are you after
The body hahahahaha
1 tubb finished earlly mark from work.
FATBOY
fatboy
0414712441
DN2168
Awesome as per usual Pete.
