Air Con in my V6 FC
Started by jfk, December 07, 2013, 12:05:15 PM
jfk
Hi all
Just wondered if anybody could give me some info on installing AC in my V6 FC. Sounds pretty soft I know, but I have moved to Far North Queensland, it's a daily driver, it has a black roof, it's summer and I'm getting old. I have a floor shift, modified bench seat, billeted steering column and a modified dash with Smith's guages, so I won't to keep it as neat and hidden as possible. Any suggestions before I get started ?
JFK
Use a VS V6 compressor. V6 conversions do a mount kit to the V6.
Nez out
I am currently playing with a vs  v6 compressor on a series 2 ,an old under dash air compressor  an looking for the right size condenser  and will fit it all in a 2seater '48 Vauxhall that is a on going project . We maybe able to exchange some ideas . Haydn
Cheers,Haydn
jfk
Quote from: Old_Mt_Isa_Boy on December 07, 2013, 01:25:23 PM
Ute or sedan?
Wayne b
Hi,
Sorry been offline for a few days travelling.
Body is a Sedan...... and thanks guys for the other suggestions...... I'll have a crack and share anything I learn.
JFK
Quote from: NES304 on December 07, 2013, 08:16:02 PM
Nez out
V6Conversions do the kit on the drivers side however I am mounting mine on the passenger side so the lines are shorter and direct tot the fire wall where vintage air is mounted behind glovebox
The VS compressor is smaller than the VT or V8 versions but has ample power to run the air con.
Nes  is it put on the drivers side solely because of the battery tray . I am just wondering because on the V6 its set up on the other side and in my Vauxhall I was thinking of leaving it as is . Haydn
No idea regarding the battery tray but Pat Gardner lifted it to avoid the chassis rail I believe. My Battery is in the boot ;D
Thanks for that . As I have to take the Vauxhall coupe body off the chassis to box it I'll take a look if it fit on with original alloy mount . Otherwise I may have to build a bracket to relocate higher unlike an early holden the inner guards are perpendicular and therefore no more room further up . Probably less room due to the original V6 manifolds . Thanks again.  Haydn
