HK front end
Started by MRJ68, July 31, 2013, 08:06:10 PM
MRJ68
with the hr front ends getting scarce on the ground has anyone done a conversion with a hk front end , are these adaptable . I know that the chassis mounts would have to change but unsure of the track.
K T G there too wide  you can use LH LX with some mods.
where are you located ?
HR front ends are around.
There are a couple that are being engineered in Adelaide ATM so I think people are doing the Torana one and getting them passed, perhaps suiting a front mount rack application for some particular reason. I have a good front end in my paddock.
Perhaps this is worth a read.
http://www.gmh-torana.com.au/forums/topic/10875-lh-front-end-with-uc-rack/
#3
Trilogy originally had a modified HQ front end (from memory),
by the time you modify something to fit you might be better off dropping 5 gorillas on one of the many front-ends being scratch built around the country. Waddingtons? Rod-Tech, V6 Conversions and I think there is another one or two.
Old Oldens in SA are (were) converting LH/LH front ends too.
FATBOY
Just put a southern chassis works front end in all problems solved
regards fatboy
fatboy
0414712441
MRJ68
yer thanks boys , but with everything freight with front ends is the hassle , oil and gas has put the prices up on freight will do a bit more hunting around to see if i can get front end closer than going 1500ks away.
Says Roma Pete, not the gay capital NSW  :D :D :D
