Wtb gemini booster
Started by ekdave, July 22, 2013, 06:59:45 PM
ekdave
Anyone got a spare gemini booster from a conversion
They are not going ahead with ?
Cheers Dave
***just cruise***
                    FB-EK HOLDEN CAR CLUB
           OF SOUTH AUSTRALIA INCORPORATED
http://adelaideearlyholdens.forumsplace.com/index.html
There about as hard as 200B ones to find at the moment... Good luck ill ask bloke up the road with geminis.
bonnet in good condition $80
guards in good condition abit of surface rust but nothing bad $70 each
doors all rust free $80 each
headlights x3 in good condition $100 a pair
taillights x2 in good condition $100 a pair
centre console auto $30
gemini hand brake setup cable and handbrake and brackets $70
td tg bars x2 in good condition $120 a pair
petrol tank in good condition $60
gemini windows back and front in good condition $80 each
gemini seats out of slx with matching door trims in green/blue $300
booster in mint condition with xb master $150
side mirrors that control them from your door trim x3 $100 for all three.
few more parts i have
0478153495
Thats what my sedan has. $220 from summit
The cheap arse booster fits the wilwood cylinder
Crumpsnr
What cheap arse booster would that be Pete?  Ta, Martyn
The one at Pete's shop  :D :D :D
The ebay one at the top of the page bolted up to the wilwood one
On the subject of boosters...
how can you tell a double diaphragm booster from a single..  physical size?
I'm leaning toward using an OEM booster versus a cheap ebay one, as I read the ebay ones are not rebuildable..  is there truth to this?
Pete I think Datsport sells the 200B boosters. I've got a 1200 booster at home and they are tiny little things, I think they are similar to the 200B. Would that provide enough boost?
A 200 is a fair bit bigger than a 1000 and a 180B is different again and i was running a 200B on the sedan and wasnt overlly happy with it im going to check it right out before i use it as the ute has a bit more poke than the sedan use too.
Quote from: FCRB26 on July 23, 2013, 10:29:55 AM
Think from memory the Gemini booster has about 860 lbs of force only good for a light weight car ......FC427.......
ekdave
Thanks guys
Was going to run the gemini booster and commodore
Master
4 wheel commodore discs
Thought the gemini booster was the norm for this set up ?
Cheers Dave
***just cruise***
Crumpsnr
Quote from: FCRB26 on July 23, 2013, 05:39:22 AM
Thanks Pete  :)
