Push button switch next to column
Started by fe350chev, June 05, 2013, 10:37:21 PM
On the fe I noticed the other day it has a switch to the left of the column. Is a white push button switch. Would this be a normal place for the heater switch or is it likely something else.
collecta
  Sounds like it is something else. My old FE had a warmaride resistor type dial switch in the dash, right side of the column. dealer fitted.
Scott
collecta
Could be for the horn, mine had the same but I found a broken wire under the dash so that solved the need for it.
Regards Jim
Is this the taxi i cannot keep up which car your on? might be taxi light if it is?
Just guessing tho..
Na its on the Boonie mobile from Pimpinio, Victoria, so I dont see why they would have used a horn  :D, ....only to round up sheep!
