re dropped spindles
Started by FCRB26, December 18, 2012, 10:50:17 AM
I am on the lookout for a set of dropped spindles to suit commodore brakes if anyone can help.
Pete your a couple of weeks to late sold to a guy in Tas ,,,,,FC427........
Geoff_K
Hi Pete,
I have a new STUBTECH set (17.9.11 with paperwork) to following detail:
STUBTECH STUB AXLESâ€"RANGE OF MODELS.
HD-HR Standard Steering: Brake callipers are mounted to the front, steering arms to rear
and are bolted to the lower holes.
HD-HR Rack 8, Pinion Steering (Torana): Brake callipers to rear, steering arms to front, and
bolt to lower holes.
HK-HT-HG: Brake calliper to front when using Girlock callipers. All others do not matter.
Steering arms to the rear, bolt to top holes.
HQ-WB:  Brake callipers to rear, steering arms to front, and bolt to top holes.
LH-LX-UC: Brake callipers to front. Steering arms to front and bolt to lower holes.
Tapped hole in steering arms to be drilled out to accept a 7/16" UNF Grade 8.8.
LC-LJ: Brake callipers to rear. Steering arms to front and bolt to lower holes. Must be
stamped 90•
STUBTECH STUB AXLE WILL LOWER CAR APPROXIMATELY:
MODEL     DROP AT WHEELS      WHEEL DIAMETERS
HK-HT-HG-WCI-WB     50mm     14" Wheels
                                               7.5 degrees
HD-HR                       60mm     13" Wheels
                                               7.5 degrees
LC-LJ-LH-LX-UC         60mm      13" Wheels
                                               9 degrees
I understand that Commodore Hubs/Stud Pattern/Brakes fit, but you would have to verify (as I was going to fit Std HR brakes/hubs)
Interested?
Geoff_K
Thanks for the offer Geoff but a member rang me today with an earlly CRS set so i will go that way as he wants to barter with me so im very happy with that..
Ill let you know if i have any dramas.
Peter Mallaby
