All Aussie 3 speed to HR bell housing
Started by Splod, May 12, 2012, 11:57:01 AM
Splod
Hi
I was wondering if anyone could tell me if the all aussie 3 speed from a HQ/HJ would bolt up to a 186 from a HR with HR bell housing? Do I need to change the bell housing to a later model? It seems ideal to use the HR bellhousing due to the clutch slave cylinder already being in situ rather than use the HQ/HJ and a Dell conversion for the slave.
Splod
Mildura, Vic, 3500
ACE
Hi Splod,
No, You need to use the matching bellhousing,clutch,pressure plate and a Dellow or similar bracket and a FE- EK slave cylinder and a tailshaft, shifter and speedo cable to suit.
ACE  8)
Splod
Quote from: ACE on May 12, 2012, 12:24:18 PM
Hi Splod,
ACE  8)
Thanks ACE. That was what I needed to know.
Mildura, Vic, 3500
