Steering Wheel Resto.
Started by Stash, April 30, 2012, 02:59:34 PM
Stash
Hi all,
Has anyone used POR15 /KBS top coats on an original steering wheel?  ???
Seems a logical paint being polyester, super hard and flexible.
interested in opinions.
graham_fuller
Yes i have used Por15 on a steering wheel. You just need to use a clear coat over it that is UV stable.
Works a treet.
Graham
Stash
Cheers graham.
Was thinking the Kbs top coat might be the way, as it is Uv stable.
Stash,
I've used ordinary acrylic lacquer on Holden steering wheels without problem.  The main thing is to put quite a few coats of paint on the rim of the wheel so it doesn't rub through over time.
And as for cracks - there isn't much you can't fix with a die grinder and bog.
Brad
    I did a wheel for my FB years ago and filled the cracks with araldite after I openend them up a bit. Then filed / sanded the wheel smooth and gave to a mate who painted it with 2Pac and it came up sweet as.   The POR15 should work fine as it has a great finish and gloss so would look A1. Not sure about UV though.
  Brad.
Stash
Agreed Rob & Brad
used an epoxy 2-part putty..
Was looking at equivalent to POR15 but with UV.
http://www.kbs-coatings.com.au/kbs-blacktop-chassis-paint
zl296
seen the black top painted on a chassis the other day....
goes hard as...
panel beater hit it with a hammer,did not chip...
but is $$$$$
Stash
Sounds like the stuff then...
