hr front end with uc brakes
Started by ehholdenman, July 09, 2011, 08:34:23 PM
ehholdenman
Hello all
Wanting to known if a uc torana caliper and hubs would fit on a hr stub axle and if so can i still run hr steering arms
Thanks for your help in advance
That is exactly how I built my FE. You need to carve a bit out of the upper wishbone for clearance on full lock, or weld in some longer bump stops which will reduce the turning circle.
