FE sedan project
Started by BLOK, December 25, 2010, 06:48:31 PM
FE 4 ME
Oh yeah thats right i just remember earlier in your thread the pic of the Blue viper...be very nice...
hope your having fun, cause it certaintly fun reading and watchn your good fast work
enjoy
FE 4 ME
DN2168
Hi Blok,
That blue really sets the car off, will look unreal when it has a full coat on it.
Hope you got some done today cause it's not real nice weather here in Casino :(.
Dean.
BLOK
The sun came out for while so I got the finishing coats on the engine bay ,if your ever down this way Dean you will have to drop in and have have a chin wag
DN2168
No worries Blok,
we will be down your way 10th July for the BMX state of origin. If I get mine finished by then I might take it for a run.
Dean.
BLOK
Here's the bay with the finished coats and gloss on it
and before and after gloss on the dash surround
Yep looking the part BLOK.
Wayne B
BLOK
Got into it again today ,heres before and after shots
BLOK
This was the boot out of the corona, worked well
On ya BLOK.........what a difference a day makes  ;)
good to see the hard yards paying off, keep up the good work
Gary
Nice work BLOK ...Are you going to weld a reinforcement plate around the gear shift opening should be  50mm all the way around  ??? ??? ???......FC427......
BLOK
Thanks for the encouraging comments guys I'm really stoked at how she is coming along, i had my sons 21 st to sort out yesterday so i put the effort in today and its amazing what you can acheave when you can see what you will have at the end of all the hard work , all went fairly well today but i don't encourage trying to install an engine on your own ,i have a couple of scratches to fix up ,i hope the neighbours didn't hear me every time the engine  hit the paint oops
BLOK
Did not know that FC427 what exactly is the purpose is it because the cut out weekens the tunnel although i wouldn't think so
Quote from: BLOK on April 03, 2011, 07:37:44 PM
Blok  Yes it does weaken it, had the discusion with the engineer Why ?? GMH never did it from factory why do I have to reinforce it [Torana HQ HZ } but that didn't work  ??? ??? ???....It is one of the first things the RTA put up on there Guidelines for Light vehicle Modifications issued April 1994... It's an easy to do 1/2 hour job now big job when the cars all trimmed and assembled.....FC427.....
BLOK
Yes mate easy fix now ,can you tell me what the required thickness of the reinforcing plate is ill cut one out at work cheers
I usually use 1.2 mm ...FC427.....
BLOK
lot of rain this week but played around with the throttle linkage ,used the bits off that corona and it seems to work well
i was able to use the original throttle linkage and adapt to the WW twin barrel stromberg using the corona part
BLOK
Knocked up the centre consol today using cardboard as template and then cutting out the MDF was fairly fiddly job but it came up OK
Nice... Will look good when its finished.  ;D ;D
