grey motors
Started by feggle, December 21, 2010, 09:58:37 PM
feggle
does anyone know the difference between fc and fb grey motors.regards jeff
FCGos
Feggle
My knowledge is scant however I know the FB series had a larger bore and pistons which gave them 138 cubic inches over the FC's 132.5 CI.  I think there was a slight change to the cam profile but apart from that I am not sure.  However anecdotal evidence would state that the longevity of the FB engines was somewhat lesser to that of the FE, FC range.
Hope this helps
Wayne
the fc is likely to be a more lighter shade of grey due to age lol  ;D
Quote from: feggle on December 21, 2010, 09:58:37 PM
Hi Jeff,
FE and FC engines have an "L" prefix for the engine number. The first FE engine number began at L283373. The first FC engine number began at L439507 and concluded at approximately L640000
FB engine numbers began at B1001 and continued through the EK range with a B prefix. EJ engine numbers commenced with J1001
Internally FC engines were of a 3.00" Bore, and displaced 132.5 cubic inches, the FB were a 3.0625 bore (3 and 1/16 inches) and displaced 138 cubic inches.
As the grey motor evolved, casting techniques improved.
I hope that this has helped answer your question
F4+ ;)
feggle
Thats great thanks for the info .jeff.
GOA350
Also check the size of the welsh plugs and the position of the cast strengthening ribs on the side of the block. Also the FB head has 2 water holes drilled in the top at opposite end for temp sender position and heater pipe. I 'm sure the gurus will confirm this or deny it.
graham_fuller
hi Scott,
The head certainly has the 2 water ports you speak of.
Graham
