Shifter Linkage Bushes
Started by Glenn 'Stinky' Stankevicius, October 01, 2010, 11:06:12 PM
I will be piecing together a Speco Shifter and modified linkages for an Aussie 4 speed soon, just wanted to find out if anyone knows where I can get new bushes for the linkages as the ones I have are worn  :'(
Spinner
Stinky,
Go out in the mulga.  Plenty of 'new' bushes there.   :D
So anyway, couldn't find the right size bushes out in the Mulga, anyone else?
Hi Stinky,
What bushes are you after? Is it the the bushes in the centre of the shift, ie the gear lever pivot bushes? If you are happy enough to send me your shifter, I have access to a lathe, perhaps I can turn you some up if you can't find some replacement bushes.
F4+ ;)
I am trying to use a Speco Twin-Stick shifter, unlike the factory shifters that have the pins to attach to the linkages this shifter has holes that require a bush 12mm OD/9.5mm ID then I need some 9.5mm pins with a 15mm(approx) shank. The pins aren't so hard, it's the bushes I really need to source. The only bush that came with the shifter is plastic, I just need 2 more.
Shayne
Stinky, have you tried a long-time Speco supplier on the off chance they can help?  Is it Motor Traders in South Aus?
Good idea, that's usually the last place I go.
Problem solvered [ebay]320558881012[/ebay]  ;D
Gotta be happy with that!!
F4+ ;)
Quote from: EffCee on November 02, 2010, 07:51:17 PM
Yep, everyone like likes a nice tight bush  :P
Quote from: stinky on November 02, 2010, 08:26:21 PM
Each time you put your hand on it you will be able to feel it slide in and out :P :P
;D ;D ;D
F4+ ;)
jack_fc
geez, you two; get a hold of yourselves...   ::)
