Celica Gear Box Yoke
Started by Digger, December 08, 2002, 02:31:11 AM
Digger
Hi,
Any one Know what holden tail shaft yoke fitts the celica gear box (5 speed) I have used one from a holden Jap built car before but can not remember what it was.  ???
Any help will appreciated. Its the last thing to do to get the car going.   :D
Regards,
Steve.
From memory when I did this a few years ago, you use the Celica yoke and the uni is the same as the holden uni - OR - when the tailshaft was shortened, I used the front of a Celica tailshaft and had it welded to the Holden tailshaft.
I definately know that I used the Celica yoke.
Digger
Thanks Ken,
I may have to weld the Celica end of the tail shaft to my shaft the Celica uni cap is .54mm wider in diamiter than the Holden.
I could have sworn that i had used a yoke from some thing else and it had the same size uni as the holden.
O well i will have to get the hacksaw and welder out.
Steve
FC2104
Digger
You may have to check but i am pretty sure that the yoke from a starfire four powered toyota corona has the same uni
Dean
Digger
G'Day Dean,
Thanks mate, I new there was a yoke that I had used once before.
I didnt get to do the shaft today (luckily), I was stuffing around with the mounting brackets for my bucket seats.
I will give the wreckers ago Monday.
Steve.
FC2104
DIGGER
LET ME KNOW IF IT IS THE SAME
DEAN
Digger
Dean,
You are right, the tail shaft from a 1981 Toyota Corona (XT-130) with 1.9ltr starfire motor.
Haven't found one as yet this morning but when i do i will let you know the price.
Steve.
Digger
#7
Dean,
No go, the XT-130 carona that I looked at today has a Borgwarner gear box fitted with the lager uni size.
Still looking even if its to convince myself that I had used one that fitted the Holden uni.
Steve.
