NASCO OIL FILTERS
Started by freddyc, June 18, 2008, 08:00:42 PM
freddyc
Can any one tell me where to connect the lines to on the block. regards freddyc
Townsville North Queensland
Remove the oil pressure switch and fit the T adaptor which allows the hose and the switch to be connected at the one spot - this is the supply point. Directly below the oil filter there is a slotted head screw in the block - remove this and the return oil line goes in here using a tapered fitting.
Fast_Eddie
Ken,
This may be a silly question, but I take it the supply line goes to the side of the filter housing and the return to the bottom? I guess the alternative is that it supplies at the bottom under pressure and perculates out the higher outlet on the side?
Also, from memory there are two outlets in the block near the bottom of the filter. Is the slotted screw you refer to closer to the filter housing location?
Maco
Hi Ed.
If you look thru the Nasco threads which Alex posts you can find a drawing of the correct connections and fit up.
Better in Green
