November 24, 2024, 02:06:16 AM *
Author Topic: RED MOTOR DIFF??  (Read 1849 times)
fe hotrod
« on: November 08, 2005, 07:41:13 AM »
I  will be fitting a red motor diff center to my fc,what i would like to know if i change the flange to a grey motor one can i still use a grey motor tailshaft or will the lengths still be different,or if running a red motor center should i just replace the tailshaft to a red one?? hope this makes sense!!cheers  Wink
« Reply #1 on: November 08, 2005, 08:19:08 AM »
Hi fe hotrod,
You just have to change the rear uni joint when you fit a red motor diff centre. Wink
From memory you can't fit a grey motor pinion flange to the later model centre, and the fc pinion flange is the weak point on the diff centre.  Shocked
Regards ACE  Cool
Page created in 0.026 seconds with 19 queries.
