November 24, 2024, 10:50:27 PM *
Author Topic: horn stuff  (Read 5816 times)
Phantom
« on: May 24, 2004, 10:49:46 PM »
G'day all ,
                  Ken can you help me here please? here is a pic of my steering column , i have all the bits in the steering wheeel for the horn, but am i missing part number 3 and 3a(from the manual), the part with the wire ? and where does it connect to?
                            Cheers Rusty
Bogans rule
graham_fuller
« Reply #1 on: May 25, 2004, 01:07:16 AM »
hi Rusty,
The part you refer to is the bakelite mounted Brass disc.This part screws to the front of the Black cover where the nut inserts are.
Graham
Phantom
« Reply #2 on: May 25, 2004, 01:18:04 AM »
Cheers Graham, thanks fgor your help
                  Rusty
Bogans rule
« Reply #3 on: May 25, 2004, 10:08:33 AM »
I will send these bits 2 youalong with the attaching screws
Regards  Ken
Phantom
« Reply #4 on: May 26, 2004, 03:46:43 AM »
G'day Ken,
                   You are an absolute champion mate, will be waiting for the postie,
                                    Cheers Rusty
Bogans rule
FEHOLDEN
« Reply #5 on: May 26, 2004, 10:25:49 AM »
het rusty
coldnt help noticing your stick poking up out of the floor Embarrassed what box are you running? is it m20?
denis
Phantom
« Reply #6 on: May 27, 2004, 03:20:35 AM »
g'day FE holden, it is a speco three speed (i think)
                                Cheers Rusty
Bogans rule
Spinner
« Reply #7 on: May 27, 2004, 07:00:55 AM »
  Wink Wink  Hijack alert   Grin Grin
Rusty,
Aren't all parts of an FE or FC 'horn stuff'?   Grin Grin Grin
Spinner
Phantom
« Reply #8 on: May 27, 2004, 07:04:05 AM »
Yes spinner if it turns you on that way
                            Cheers Rusty
Bogans rule
RUBBLE
FC WAGONS ARE COOOOOOL
« Reply #9 on: May 27, 2004, 07:09:08 AM »
Hey Rusty, Cool
What gearbox are you using to keep the benchseat without any mods Huh
cheers RUBBLE
Phantom
« Reply #10 on: May 27, 2004, 07:14:52 AM »
Rubble ,it is a speco three speed
                                Cheers Rusty
Bogans rule
Effie C
Still Lost & Confused
« Reply #11 on: May 27, 2004, 09:58:39 AM »
Rubble and Rusty
A speco three speed is the shifter, attached to either the original three speed gear box or if tunnel is modified a later model three speed box. Speco is a brand of shifter not a brand of gearbox.
John M
Phantom
« Reply #12 on: May 28, 2004, 05:34:38 AM »
Thanks effie ,as you can see i am no mechanic, it must be the original box then
                                                 Rusty
Bogans rule
Effie C
« Reply #13 on: May 28, 2004, 09:25:49 AM »
No worries Rusty,
I'm no mechanic either, just a refrigerated sparky. There was another brand of shifter available in the dim past called an impalla,this was a sraight line shifter not a H pattern unit like yours,I also seen a single piece of metal rod used to change gears a s well, not fancy but it worked.
John M
Phantom
« Reply #14 on: May 29, 2004, 01:10:24 AM »
G'day effie,
                        Thats all i got a straight bit of rod to change gears , dont look too good but it works
                                      Cheers rusty
Bogans rule
