July 17, 2025, 08:13:50 PM *
Author Topic: What is the right size bolt..  (Read 3471 times)
Laszlo
« on: June 08, 2021, 09:22:11 PM »
.... for a boot emblem  ?
In the bolt and nut shop they tried to tell me I need a 12/24. Wasn't the right one. I did try a metric 4, not too bad but not perfect. A little bit loose.  Maybe just the age of the emblem and a rechroming.....
Thanks : Laszlo
Sent from my SM-G965F using Tapatalk
Holden = The Heartbeat of Australia
Stewy
sa-club
Jeff Stewart
« Reply #1 on: June 08, 2021, 09:34:30 PM »
Parts book says :  SCREW round head. cross recess No. 10-24 x 1/2" with lock washer x2
Cheers Stewy   Cool
Laszlo
« Reply #2 on: June 08, 2021, 09:54:48 PM »
Thanks Stewy !
That was quick.
Laszlo
my8thholden
« Reply #3 on: June 09, 2021, 07:57:47 AM »
check to see if somewhere in its life the thread hasn't been damaged or brutalised to make something fit ,or clogged with chrome ,carefully use a 24TPI tap to clean up...cheers Vern
Laszlo
« Reply #4 on: June 09, 2021, 08:43:31 AM »
Thanks Vern I will try that way.
I started to change all the bolts ,screws and nuts for stainless steel one. So if someone  has to take the Fe a part 60 years time no rusty surprises..... : )
Cheers  : Laszlo
« Reply #5 on: June 09, 2021, 10:09:04 AM »
Laszlo,
3/16" Whitworth is also 24 TPI.  OK, so the thread profile's slightly different, but it will substitute for 10-24 UNC no problem.
Laszlo
« Reply #6 on: June 09, 2021, 10:39:29 AM »
Thanks Rob !
I did find some 10-24UNC stainless steel 304 or the good stuff 316 at Anzor
Page created in 0.042 seconds with 19 queries.
