July 13, 2025, 09:07:50 AM *
Author Topic: air chief radio model ?  (Read 8517 times)
pbh0069
sa-club
« on: May 15, 2017, 10:23:39 AM »
picked this up last week , any body know what model it would have been for  Huh  Huh  Huh
 no markings or numbers on the unit.
cheers Phil.
« Reply #1 on: May 15, 2017, 12:21:48 PM »
Phil,
I'll take a look through my service info for Air-Chief radios and get back to you.  There will be a model and serial number stamped onto the radio's case somewhere, and failing that, a small sheet detailing transistor or valve part numbers glued onto the inside of the top cover.
I'm guessing it's a hybrid, with twelve-volt valves and a transistor audio amplifier.
pbh0069
sa-club
« Reply #2 on: May 15, 2017, 12:30:37 PM »
« Reply #3 on: May 15, 2017, 05:57:45 PM »
The radio looks like a Vauxhall / Chevrolet radio
The adaptor probably suits one of the other.
pbh0069
sa-club
« Reply #4 on: May 15, 2017, 07:07:01 PM »
Hi Rob
no markings on the outside , opened up and found the paper sheet inside looks like the # is A.R.M.1315/279
cheers Phil.
KFH
« Reply #5 on: May 16, 2017, 08:52:34 AM »
Nothing in my Airchief files.  Possibly the model number is stamped under one of the brackets. The number is usually quite small in height around 1/8". I have also seen the model number stamped on the base of the radio.
« Reply #6 on: May 16, 2017, 10:27:55 AM »
Phil,
It's an Air-Chief JQY or CQY.  Your photos just show the tuner section.  You should also have the audio amplifier module, which is an open sheet metal chassis with a transformer on it.  Astor designed them as a "universal" radio, they also came out with a six-volt model.  The fascia is for FE-FC, and because the radio's wearing Air-Chief badges, I reckon it was sold under the NASCO brand.
Did it come with a speaker?  The Astor service sheet shows the radio with A-S-T-O-R on the pushbuttons, and a long, narrow Bakelite enclosure for the speaker.
I have the servicing information, and can even repair it if needed.
pbh0069
sa-club
« Reply #7 on: May 16, 2017, 11:06:28 AM »
Rob.
all I have is what is in the photos , I have contacted the person I got it off ( he is cleaning out there fathers shed ) and he's away at the moment , he is going to look for the rest for me when he gets back.
if I don't receive the amplifier/power/speaker assembly we will have to make one up.
cheers Phil.
KFH
« Reply #8 on: May 17, 2017, 08:44:08 AM »
I have a long narrow speaker assembly if you need one.  From the size of the speaker is 7'x5"
pbh0069
sa-club
« Reply #9 on: May 17, 2017, 10:49:58 AM »
Cheers Keith
will let you know after I find out if the rest of the unit is available.
cheers Phil.
KFH
« Reply #10 on: May 18, 2017, 09:03:56 AM »
Correction to my comments on the speaker size.  I meant to type 7"x2"
Page created in 0.048 seconds with 20 queries.
