September 02, 2025, 12:50:49 PM *
Author Topic: Temperature Idiot Light  (Read 5844 times)
« on: November 23, 2013, 08:43:52 PM »
With a standard grey what is the temperature the idiot light should activate? Is the circuit a normally closed or a normally open. Still having trouble with overheating but now think it can only be the temperature sender from the radiator (radiator has a unit fitted to top of tank).
Thanks in advance, Regards
Wayne b
Stewy
sa-club
Jeff Stewart
« Reply #1 on: November 23, 2013, 09:20:43 PM »
Hi Wayne,
The circuit remains open until the engine overheats and reaches approximately 217 degrees Fahrenheit.
Cheers Stewy   Cool
« Reply #2 on: November 24, 2013, 07:56:38 AM »
Thanks Stewy.
..........103 degrees Celsius.
If I had 13 psi radiator cap would that make the upper limit about 107 degrees Celsius instead of 103?
Next question.
To run the idiot light and a temp gauge do I need a 3 pin coolant sensor from the trident range http://www.tridon.com.au/Products/Product.aspx?SG=8&S=35&G=483&P=2013 or a Water Temperature Switch (Warning Light and Gauge) http://www.tridon.com.au/Products/Product.aspx?SG=8&S=35&G=483&P=2012?
My thoughts are I need a TTS521 (warning light and gauge) and I think that will run both the smiths temp gauge and the idiot light.
Note! I have an m16 x 1.5 thread tapped into the top of the radiator.
Again thanks for your help.
Overheating is a pain in the arse. Angry
Wayne b
jwm
« Reply #3 on: November 24, 2013, 01:42:40 PM »
Not sure if this will be helpful but it gives you a bit of information:
http://www.tuneruniversity.com/blog/2011/06/beating-the-heat-advantage-of-a-high-pressure-radiator-cap/
Roughly speaking, ever 1psi we go up on the radiator cap pressure raises the boiling point of the system about 2 -3 degrees F.
Keep in mind also that on a lot of the older cooling systems some people actually suggest that you don't completely fill the cooling system, leave it about 1 to 1 1/2 inches below the full mark on the top radiator tank.
Higher pressure caps are also recommended for modified / performance motors. I'm actually running a 16psi cap on my car with a 305 chev in it. I think if you hunt around you can actually get caps up to 18psi.
« Reply #4 on: January 31, 2022, 09:16:44 AM »
I am changing the configuration of the sensors and was hoping someone may know of an OEM sender unit 105±3°C 1/8-27 normally open. Needs to be 2 pin for both the idiot light and gauge. The manufacturers do not specify OEM units on their web page. I have contacted Tridon and they cannot help. Has anyone put a sender unit on a lathe?
Wayne b
« Reply #5 on: January 31, 2022, 01:12:53 PM »
Might be easier to give Howards a call.
http://www.howardinstruments.com.au/
« Reply #6 on: January 31, 2022, 07:41:56 PM »
Perfect thx
Wayne b
« Reply #7 on: February 01, 2022, 08:46:49 AM »
I will be talking to Howards today however for the clever one's amongst us does this solve the problem?
https://www.aisat.com.au/our-products/automotive/v230-093/
Wayne b
« Reply #8 on: February 01, 2022, 02:54:42 PM »
Don't believe so.
Some temp senders are "earth return". They have one pin. You send +12V to it, and when the coolant is hot enough the internal contact shuts, letting the +12V flow to earth through the engine block.
Other senders are "insulated return". They have two pins. You send +12V to one pin, and when the coolant is hot enough the internal contact shuts, letting the +12V flow to earth through the second pin.
I think the V230 093 is the latter... just a switch, not a combined switch and variable resistor (for idiot light and gauge).
« Reply #9 on: February 01, 2022, 05:51:20 PM »
After speaking with people today I have abandoned the idiot light and ordered a Smiths Temp Sender, from Howards, to match my Gauge. I will get over not having a light.
Thx Harv for your input.
Wayne b
Page created in 0.048 seconds with 20 queries.
