November 28, 2024, 02:06:52 AM *
Author Topic: FE Bonnet Emblem on FC  (Read 1604 times)
HARKO
« on: January 04, 2003, 10:54:59 AM »
Was it a standard practice to use the leftovers from FE.
I like the look of the FE emblem a lot more than the FC but why is it there ? After all the car is an FC 58 model
« Reply #1 on: January 04, 2003, 11:14:18 AM »
Hi Harko
I have also had a couple of FCs with FE bonnet emblems.
I think they must have been put on at a later date.
Regards ACE Cool
« Last Edit: January 04, 2003, 11:16:06 AM by ACE » Logged
« Reply #2 on: January 05, 2003, 03:13:51 AM »
There's also quite a few FEs getting around with FC mascots on their bonnets.  Maybe personal preference, maybe the result of a replacement bonnet.  It certainly wasn't standard practice to use leftovers as I understand it.  That doesn't mean it never happened but it's more common to see FC bits and pieces appearing on the very last FEs.  Graham Fuller's FE is like this - it has rubber mats in the back rather than carpet, and was like that since new.  I think Cat's car might be the same.
There's a whole heap of little things deleted or changed on the FC to cut costs - GMH wanted to release the FC at the same price as the FE, so a few things were trimmed.  The replacement of the bonnet button and surrounding die-cast trim with the 6 letters is one example of this.  The aforementioned carpet is another, as is the deletion of boot-lining and the front number plate surround.  Also the proper door-pull armrests were replaced with the much cheaper versions on the FC.  They had to pay for those die-cast fins somehow! Wink
« Last Edit: January 05, 2003, 03:19:46 AM by ret » Logged
Page created in 0.027 seconds with 20 queries.
