July 28, 2025, 11:52:36 PM *
Author Topic: Heater Duct Wanted  (Read 2760 times)
REDMR2RED
FC Ute's d'best
« on: September 30, 2008, 04:14:17 PM »
I'm after the 32mm ducts that go from the Nasco Heater "Y" piece to the Deminster vents in the Dash Board for my FC Ute.  The passenger side one is about 450mm long and the driver side one is about 900mm long.
I've tried Scott's Old Auto Rubber in Oakleigh and they rang back today to say it is no longer made and no stocks available.   Angry  Angry  Angry
The next best thing available is 32mm vaccuum cleaner pipe or swimming pool hose.
Kevin
1959 FC Holden Ute
FCOV6
« Reply #1 on: September 30, 2008, 05:24:59 PM »
What about some kind of sleeve then use whatever common size you can get ?
smithy
yeah its purple !
« Reply #2 on: September 30, 2008, 06:28:33 PM »
hi kevin, i know its not original nor resto but i ended up using the 32mm swimming pool hose. pretty durable, available and will work, but if you are after original then  Huh Huh Huh Huh
dean
« Reply #3 on: October 01, 2008, 05:17:48 PM »
Guys,
go to Clarke rubber and get some convoluted hose (vac hose, pool hose etc).
my local had different sizes.. i used one with the same OD as the heated duct.
I slipped a rubber hose as an adaptor over the heater duct  and the duct hose in the other and clamped together.
I attached the ducts using "speed clips" (speaker clips).
hope this helps.
« Reply #4 on: October 01, 2008, 05:18:45 PM »
exactly.  Cheesy Cheesy Cheesy
REDMR2RED
FC Ute's d'best
« Reply #5 on: October 01, 2008, 05:22:29 PM »
Thanks all for your advice .........
I'm off to Clark Rubber.
Cheers.
1959 FC Holden Ute
« Reply #6 on: October 02, 2008, 09:32:07 PM »
I used the tube that transfers hot air from the exhaust manifold to the air cleaner ,used on early Commodores and Jap cars your spare parts shop should carry this item as a universal replacement part in a few different sizes and it just stretchers out to length and ''resembles'' the original product ......FC427.....
