April 20, 2024, 09:13:55 PM *
Author Topic: Bumperette bolts  (Read 5564 times)
Fast_Eddie
« on: June 02, 2007, 01:12:13 AM »
Posting on behalf of Chuck who won't have access to a PC for a couple of days...
Wanted:
A pair of the special bolts that go under the rubber buffer on a ute/panelvan bumperette.
These bolts have a flat round head and a raised section behind the head that locks into the rectangular hole in the bumperette, enabling them to be tightened. (Similar concept to a standard round headed bolt)
Please contact "Chuck" directly by PM or call him on 0400 474 324 - thanks
« Reply #1 on: June 02, 2007, 01:52:01 AM »
I know it's not very hi tech or original but I just used zinced roofing bolts?
of course it may not match the chrome on the bumper exactly....
« Reply #2 on: June 02, 2007, 02:19:49 AM »
These are aslo available from Rares,P/N BB1004...Cheers,Jamie.
Fast_Eddie
« Reply #3 on: June 02, 2007, 07:57:38 PM »
Guys, thank you for your comments however we are not talking about standard bumper bar bolts.
The bumperettes fitted to utes and panelvans have a very distinctive bolt that locks into a hole in the bumperette (similar to a standard bumper bar bolt) but has a flat head almost like a thick washer that fits into the rubber buffer that is on the outside of the bar that would prevent the tailgate hitting the spare wheel door.
In the photo below, the rubber buffer I'm talking of is diagonally below the tailgate hinge. The standard bolt (which is not required) is on the side.
Jonno
« Reply #4 on: June 03, 2007, 07:15:26 AM »
I found these on ebay (seller ID 'jen-shan'). Not sure how authentic they are but they seem to do the job. Might be worth asking if she (?) has any more...
Cottles Bridge, VIC
Fast_Eddie
« Reply #5 on: June 03, 2007, 10:23:07 AM »
That's the ones! Thanks, I'll follow up.
Jonno
« Reply #6 on: August 11, 2007, 08:40:41 PM »
as if by magic...(but may be a tad late)
http://cgi.ebay.com.au/FE-HR-NOS-BUMPER-BOLTS_W0QQitemZ130142593133QQihZ003QQcategoryZ32057QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Cottles Bridge, VIC
Roybeth
« Reply #7 on: August 01, 2021, 08:13:48 AM »
Hi all,
I've found the description for the bumperette rubbers a bit confusing when trying to purchase.
Do the bolts go through the centre of the rubbers, or is the bold head inserted into a section in the back of  the rubber, ie they don't slide through a tunnel going the whole way through the rubber?
TIA
« Reply #8 on: August 01, 2021, 09:48:26 AM »
Roybeth
The bolt does not go through the bump rubber
FE - EK
Later models it does
The special bolt that locks into the bump rubber is now reproed on Epay although with patience it can be made
Gary
« Reply #9 on: August 01, 2021, 10:01:36 AM »
To make them, go to your bolt shop and buy 2 cup head or dome bolts the correct diameter in stainless steel
Flie or grind the dome down so it's flat on top and test fit it in the recess in the bump rubbers available from Rare Spares
The square section of the bolt below the dome can be filed down to suit the recess in the ute or panelvan rear bar
Gary
« Reply #10 on: August 01, 2021, 10:07:52 AM »
Helen,
John Rayner at Lismore generally has these NOS on gumtree. He is very good to deal with. I’ll see if I can dig up his details.
Clay
« Reply #11 on: August 01, 2021, 10:13:11 AM »
He doesn’t have any advertised currently but doesn’t mean he doesn’t have any.
0414271064
Give him a call.
old-blu
« Reply #12 on: August 01, 2021, 01:30:10 PM »
 Follow what Gary suggests. I made all of mine very easily. After grinding off the cast stamp, buff the head to a high polish. Kevin.
6th, may 1958 "I was there".
Roybeth
« Reply #13 on: August 01, 2021, 02:26:57 PM »
thanks everyone  Smiley
« Reply #14 on: August 01, 2021, 03:07:49 PM »
These are the ones John has. Don't know why you'd bother mucking around making your own. They weren't dear.
