rear window glass
Started by surferboy, December 11, 2014, 01:48:59 PM
surferboy
are  NEW  rear windows for sedans available
or should I hang on too the couple I have taking up space in the shed ?
Ta
8) 8) 8)
cruisin's great with a 58
Pete just bought new ones...
Not for the sedans at this stage. The glass Pete got was for the ute, they do all the side glass but not the rear(already asked them). Pete has posted that they are great quality and look great.
They can polish and repair your old windows as well..
surferboy
Ta
I will put them away in a safe place in case somebody needs them one day
8) 8) 8)
One thing I found is using clr clear which coles now sells works fantastic removes the hazing on the windows and all the other crudd then use rain x glass polish.
Here's a thought . If you stack them together ,like I did ,when' years later, you need one you will find that the constant change in temperature will make them rub against each other and you will have to get them polished . So store them with something between them [like cardboard] .Haydn
surferboy
I've had them stored behind the shed for 14 years, since I got them and some windscreens and side windows and odds and sods from FB/EKs (?)
and both side rear windows for the wagon ( are these hard to get ?)
The only thing between them is WEEDS  ;D
8) 8) 8)
