For Sale and Wanted => Parts For Sale => Topic started by: slim on May 31, 2016, 01:25:46 PM
Title: COMPLETE HR DISC BRAKE CROSSMEMBER And VH40 BOOSTER + more
Post by: slim on May 31, 2016, 01:25:46 PM
I have a COMPLETE HR DISC BRAKE CROSSMEMBER And VH 40 BOOSTER for Sale. This is still in a car In BUSBY NSW 2168 . Brakes still in Working order .  Will come as a COMPLETE Package with COMPLETE CROSSMEMBER , DISC ROTORS , STUB AXLES , CALIPERS , BACKING PLATES , ALL SUSPENSION ,SPRINGS ,SHOCKS , SWAY BAR AND ALL STEERING COMPONENTS ( not the column). Also iNCLUDED WILL BE THE VH40 BOOSTER IN GOOD CONDITION WITH ALL FITTING BRACKETS And ALL METAL LINES , And BRAKE LINES , that I can get off without Damaging . Also All the Bolts and bits that go with it .. Price is $850 FIRM  Everything you need to do the conversion basically except the Front Outrigger. Once a Deposit has been taken it will be pulled out Ready to pickup within a week . INSPECTION is at BUSBY NSW 2168.. If u want to look before you buy . Cant post photos but can send pictures to prospective buyers via Email , No problem . .  Also have a complete 186 Red motor with all bolt ons , Pulled out Running yesterday . Has  Starter motor , Generator / alternator , Stromberg carburettor , Stock manifold , Distributor ,  , Fuel pump, Water pump . Basically still a complete engine $500 .. And a Good Powerglide Automatic gearbox with Torque convertor and Ring gear / flexplate , Pulled out yesterday also running well $400..    Also have a HR AUTOMATIC STEERING COLUMN With NASCO GEARLOCK (no key)  $150  Set of Good EXTRACTORS for 186 $60  If your interested in the whole car which is a RUSTY HR GENUINE 239 PREMIER WAGON ,   Still has Original PREMIER HEATER and stacks of other good spares . $1800 FIRM   SLIM 0420768346.. ::) ::)
