For Sale and Wanted => Other Stuff Wanted => Topic started by: KFH on February 01, 2012, 07:55:02 PM
Title: FJ Holden wiring diagram
Post by: KFH on February 01, 2012, 07:55:02 PM
I am helping my brother with the wiring on a car he is restoring.  I have run into a slight problem with the method the new wiring and the courtesy/ interior switch.  I would appreciate a copy of the wiring diagram to help me out.  The FJ does it different to the FC series.
Title: Re: FJ Holden wiring diagram
Post by: slim on February 01, 2012, 08:13:33 PM
i know fj is 6 volt and fc is 12 volt .
Post by: KFH on February 01, 2012, 08:45:56 PM
The FC uses a single wire to the courtesy switch which closes to earth (body) when the door opens.  The FJ switch has two terminals neither of which goes to earth at the switch.  The two wires from the switch goes up to the interior light as does an active wire (6 volts).  The light has a 3 position switch and two terminals on to connect to. These 2 terminals are internally joined together with the outer of the lamp connected to the base of the lamp and subsequently goes to earth when screwed in position.  When the switch is in the on position the two terminals are joined together.  I fully understand the electrical side of things but this one has me  a little bambooseled.
Post by: mcl1959 on February 01, 2012, 08:54:36 PM
The FJ dome light switch has 3 terminals. The first has 2 wires on it - One is power and the other goes to the second dome light switch. The second wire goes to the other side of the second dome light switch and the third wire goes to the dome light which is earthed.
Post by: KFH on February 01, 2012, 10:01:56 PM
Thanks Ken
I think I can understand what you are saying.  I presume when you refer to the second dome light switch you are referring to the the door switch?  This car has a door switch on the passenger side door only.  The reproduction wiring harness only has wiring from the passenger door.
Post by: mcl1959 on February 01, 2012, 10:51:32 PM
That's right only on the passenger door
