For Sale and Wanted => Reproduction Parts => Topic started by: Jolls on January 19, 2024, 03:11:50 PM
Title: Water Pump/Radiator Hoses
Post by: Jolls on January 19, 2024, 03:11:50 PM
Hi Team
I set up the FC donk in the engine test stand, connected up all the hoses, filled the radiator and the water pump is leaking so I need to get another one before I can do any more testing. There are plenty of options on eBay and my sorces tell me that can still be purchased from Repco/SuperCrap. However, not sure what is cheinesium rubbish and what are quality parts - same for the hoses.
The threads related to this on the forum are not quite as old as the FC in the shed - but starting to get up there.
If you could impart some wisdom as to the best souce for water pumps and radiator hoses it would be greatly appreiated.
Title: Re: Water Pump/Radiator Hoses
Post by: ardiesse on January 20, 2024, 12:03:27 PM
Craig,
CH313 is the top hose, but I can only remember the number for an FJ bottom hose, which doesn't help.  The last bottom hose I bought for the FC said it was the same as for a TX Gemini (best to check).  Repco can get the hoses, but you need to tell them the part number because their databases don't go back that far.  Otherwise, Rare Spares.
Water pumps are a different matter.  You used to be able to get repair kits from places like Auto Surplus in Melbourne.  I have wondered about buying a red motor pump and raiding it for the bearing and seal.
Use caution with aftermarket grey motor water pumps.  In some cases, the bolt holes don't line up, and need enlarging.  The shaft sticks out too far at the front - cut it off flush with the hub.  And the hub subtly distorts the pulley.  If you have a Dremel, you need to grind four shallow slots into the hub to clear the pressed ribs in the pulley.  Or if you have a press and an original Holden water pump, swap the hubs over.
Post by: Harv on January 20, 2024, 01:32:02 PM
Lower hose: Gates part number 05-0004,  Mackay part number CH313
Upper hose: Gates part number 05-0008, Mackay part number CH482
Post by: my8thholden on January 21, 2024, 06:49:28 AM
Craig ..Check with the supplier if the hose has a mesh fabric inner , moulded hose with mesh inner is superior to extruded rubber NO mesh , original had anti suction spring , dont know if that applies or even available any more ..Vern
Post by: Jolls on January 21, 2024, 08:22:20 AM
Craig,
Thanks for the heads up Rob,
I have three original water pumps that have good impellors etc - so if I can find repair kits I am good to go. I have searched previously with no luck but will have another crack.
Really appreciate the advice on fitting up the after market pumps - that is invaluable information that I will note in the workshop manual for future reference!
Cheers n Beers
Jolls
Post by: Jolls on January 21, 2024, 08:24:33 AM
Thanks Harv,
I used the Gates hoses on the SS when I did the "upgrade" to her donk. They were pretty good quality.
Post by: Jolls on January 21, 2024, 08:25:35 AM
Thanks Vern, I will check for that before I place an order.
Cheers n Beers
Jolls
