Galleries => Original Advertisements, Brochures => Topic started by: stephen on August 07, 2010, 06:30:56 PM
Title: FC Holden & Smiths Heater Advertisement
Post by: stephen on August 07, 2010, 06:30:56 PM
Hi ..does anyone have a advertisement of a FC fitted with a Smiths beehive heater or the heater advertised to suit an FC  ?? .. Regards Stephen
Title: Re: FC Holden & Smiths Heater Advertisement
Post by: customFC on August 07, 2010, 09:19:09 PM
(http://img.photobucket.com/albums/v608/customfc2/FEFC%20instr/smith-heat3.jpg)
Check out the Accessory of the week in the club members only section for other heater options.
Post by: zulu on August 08, 2010, 12:01:38 AM
There were 2 versions of these, the Nasco badged (stickered) one has the inlet & outlet at opposite corners & was available with a set of controls in a panel that could be fitted below the radio.
There was also ducting that ran from the heater through the engine bay across the motor to the off side radiator support panel, into which a hole was cut to supply "fresh air" via the ducting to the back of the heater using one of the controls
There are probably pics of this unit fitted in as Alex has mentioned in Accessory of the Week section
(http://s2.postimage.org/bcPQS.jpg) ($2)
(http://s1.postimage.org/CVULJ.jpg) ($2)
(http://s2.postimage.org/bcZPr.jpg) ($2)
Gary
Post by: stephen on August 08, 2010, 09:01:01 AM
Thanks for your help Alex and Gary .. much appreciated .. Regards Stephen
