August 14, 2025, 04:17:24 PM *
Author Topic: fuel gauge out  (Read 2905 times)
willmoo
« on: August 23, 2006, 06:59:45 PM »
First time on, just took ownership of my first fc ute. My plans are to keep her stock and for a gradual restoration the old girls still in pretty good nick. Now my first delema is my fuel gauge is out by about 3/4. When the tank is full it's only showing about a 1/4 on the gauge. Where should i look first? Huh
« Reply #1 on: August 23, 2006, 07:23:32 PM »
Welcome aboard willmoo, the first thing to do is check that all connections and that the earth is good. Bad earthing/grounding probably causes 90% of electrical faults. Use a test light to make sure the sender wire is good and clean up any connections to gauges and the body.
willmoo
« Reply #2 on: August 23, 2006, 09:10:35 PM »
thanks for the info will have a play after work
Russ
mmm dohnuts
« Reply #3 on: August 23, 2006, 11:51:32 PM »
mines about 3/4 out to but it shows 3/4 when you sitting on the side of the road looking really stupid
willmoo
« Reply #4 on: August 24, 2006, 06:36:02 PM »
thanks for the info stinky cleaned all the terminals behind the gauge, hooked her back up and she's back to normal. saved me a real headache.
Page created in 0.029 seconds with 21 queries.
