May 20, 2025, 05:07:24 AM *
Author Topic: when was my car built?  (Read 8659 times)
FEHOLDEN
« on: August 12, 2002, 10:57:21 AM »
gidday everybody
i realise this is probably a question for king ken but can anybody give me an aproximate date of when my fe special was born? chassis number is 852258m and engine number[currently grey] j5899.
denis
« Reply #1 on: August 13, 2002, 06:56:48 AM »
Denis, I need the info from your firewall ID plate as well.
The chassis number needs to tie with the body number details in order to confirm the cars dob.
Your engine number is EJ vintage and therefore cannot be used to validate the chassis number.
FEHOLDEN
« Reply #2 on: August 14, 2002, 05:27:36 AM »
thanks ken
it might be a couple of weeks until i can get back to my mums place where the car is stored, to check details you require. will reply via this string then.
denis
FEHOLDEN
« Reply #3 on: September 20, 2002, 05:35:27 AM »
gidday again ken
i finally have those details for you:
body no: fe225-19446m
trim: 212-473
paint: 253-7699
          256-7698 top [also has letters rpo next to this. could it refer to flash along side?]
vin: 8-52258m
thanks in anticipation.
denis
« Reply #4 on: September 20, 2002, 10:43:50 PM »
I'm sure Ken willl give you an answer to your question, but I just wanted to mention that an explanation of the compliance plate codes can be found in our Tech Info section.
The second batch of paint numbers (256-7698 in your case) does indeed refer to the flash colour, but is not an RPO.  That area (the code stands for "Regular Production Option") is rarely filled in.  An example you might see on a panel-van's body plate is "333", and means that a window was fitted to the tailgate ex-factory.
Ken, what other RPOs have you seen?
FEHOLDEN
« Reply #5 on: September 24, 2002, 04:05:08 AM »
thanks for the tip ret
now i know i am a geniune member of the official and exclusive poo club Grin Grin Grin
according to tech spec tables, trim colour is castle grey over corsair tan with morrocan tan and egret ivory inside. "detriot " flash along side is also castle grey.
i now also know the car was no 19446 built in melbourne
have been trying to post a picture for all to see using paint tool craig posted some time ago but am having trouble moving into paintbrush and onto forum. if you are reading this craig, instructions posted under "poo mobile" string back in april ie alt + prtsrc dont appear to have any effect on my machine[it is a pc]
denis
« Reply #6 on: September 24, 2002, 04:54:24 AM »
alt-prtscr puts a copy of the front-most window on the clipboard.  You then need to open a new paint-brush (or photoshop or whatever) document and paste it in.  Then crop etc and convert to JPG format to publish.
Cat
« Reply #7 on: September 25, 2002, 08:32:28 AM »
YAY! Cheesy More poo mobiles......bring 'em on!  We're going to take over the poo world you know!  Shocked Maybe this will be called the poo forum in the not too distant future? Oh, and the poo colour changes between '57 and '59 .... well that's Poovolution of course!!
Cat  Grin
PS I'm looking forward to seeing that photo Denis, and particulary the detroit kit.  I was thinking about one for the poo wagon in Castle Grey.....it makes the poo go faster.........!
« Last Edit: September 25, 2002, 08:36:40 AM by cat » Logged
Zoom zoom!
FEHOLDEN
« Reply #8 on: September 26, 2002, 06:21:39 PM »
GOODONYA CAT
I'VE HEARD THAT PRUNES WILL DO THE SAME JOB Grin Grin Grin
THANKS FOR THE ADVICE RET BUT WOULD YOU PLEASE TRANSLATE INTO ENGLISH. I THOUGHT YOU COULD GET INTO TROUBLE FOR HAVING A CROP AND JPG??? WHICH MODEL IS THAT?
DENIS
FEHOLDEN
« Reply #9 on: October 03, 2002, 06:18:03 PM »
I HAVE READ THE REPLY GIVEN TO MOOKIE IN ANOTHER STRING. DOES THIS MAN MINE IS A 1958 MODEL TOO?
DENIS
« Reply #10 on: October 03, 2002, 08:04:02 PM »
Yup.  The first part of the chassis number (which appears on the inner guard), specifies the year the vehicle was made, and for FE/FC can be one of:
6 = 1956
7 = 1957
8 = 1958
FC = 1959
The scheme was changed in 1959 (meaning it was a bit more difficult to know the exact year of subsequent models).
The next number is the build number (starting from 1000, not 0), and the last letter stipulates the factory city (ie Melbourne in your case).
Hope that helps,
« Reply #11 on: October 04, 2002, 10:07:37 AM »
Denis - sorry for the delay.
Your car was built late November 1958. Very near the end of the run.  The highest Sydney chassis number I have recorded is only 1000 higher than yours.
FEHOLDEN
« Reply #12 on: October 04, 2002, 06:32:05 PM »
THANKS FOR THE INFO GENTS
JUST TWO LAST QUESTIONS
1:WHEN YOU SAY NUMBERING STARTS FROM 1000 DOES THAT MEAN I SUBTRACT 1000 FROM 52258 TO GET THE ACTUAL IE:51258?
2:DID THE LAST OF THE MODEL ROLL OFF THE LINE AT SYDNEY OR IS THIS ONLY THE HIGHEST NUMBER YOU HAVE ON RECORD KEN?
3:DOES MELBOURNE MEAN DANDENONG OR FISHERMANS BEND?
DENIS
« Reply #13 on: October 05, 2002, 11:53:26 AM »
Denis,
1    Correct
2    This is just the highest Sydney number I have. Production stopped the same time at all factories roughly.
3    Melbourne production was in Fisherman's bend up until September 1956. All FE's with Melbourne chassis had Adelaide bodies up to this time.  After that there was a phase in period in which the Dandenong production came on line - during this time some of the production had Adelaide bodies and some had Melbourne bodies.  By the end of 1957 all Melbourne chassis FE's had Melbourne bodies.
FEHOLDEN
« Reply #14 on: October 06, 2002, 01:05:55 AM »
MANY THANKS TO ONE AND AL INVOLVED
I NOW KNOW A HEAP MORE ABOUT MY CAR THAN I DID PREVIOUSLY
I'M STILL NOT SURE ABOUT THE PICTURE POSTING THOUGH
DENIS
« Reply #15 on: October 07, 2002, 02:08:01 AM »
Denis,
Once you've created your 'Painter' masterpiece, hold down the "Alt" key and press the "Prt Scr" button (far right, top row, after F1-F12).  This puts a copy of the Painter Window in the 'clipboard'.
Launch MS Paint.  Click File/New to create a new image, and make it the size of your screen (ie 800x600 or whatever it is.  If you don't know, make it 1500x1000)
Once the blank window appears, click Edit/Paste (or ctrl-V) to paste in the image from the clipboard.
All you need to do now is crop the picture by selecting only the image (and not the blank space around it) and getting rid of the excess.  I'm not sure exactly how you do this since I don't use Windows, and even if I did I'd use Photoshop, not Paint.  Maybe CraigA or someone else can assist on this one point.
The save the image and choose JPEG as the format.
Hope that's some help.
Page created in 0.045 seconds with 20 queries.
