May 19, 2025, 12:28:39 PM *
Author Topic: Twin Manifold - Carby Insulating Blocks  (Read 3057 times)
Rod
« on: June 15, 2006, 02:23:17 AM »
Hi All (again),
Seem to be asking alot of questions of late.
I have a twin carby manifold. Do you need to use the bakelite insulating block with these manifolds like singles. If so the studs would not allow me to put the carby's on as they are way to short.
Rod
HYSTERIA
« Reply #1 on: June 15, 2006, 04:00:40 AM »
Hi Rod,
I have this set up on my car and did not use the spacers due to the fact that the manifold was polished and it looked a bit funny. Mine seams to run fine without them.
Jason
EK 215 - Who needs all that chrome
EJ_Dave
« Reply #2 on: June 15, 2006, 04:48:00 AM »
Rod,
if you're running extractors the inlet manifold won't get as warm as the original with the standard exhaust manifold bolted to it and you shouldn't need the insulators.
You may need to modify the accelerator linkage a bit though because the carby will sit slightly lower. On my car (EJ) this caused part of the linkage to hit the extractors before I'd reached full throttle. All I needed to do was shorten the vertical link bit and it was sorted.
Rod
« Reply #3 on: June 24, 2006, 07:06:59 AM »
I've just finished reading a book on small block chevys and ways to improve their performance.
One point was to put in / increase size of carby spacer to increase HP.
My question then is, what is the main purpose of the "insulating" block. Was it put on a standard manifold to assist flow hence some small gains in HP?
Rod
