July 26, 2025, 07:11:15 PM *
Author Topic: Spark Plugs  (Read 1874 times)
Grah
I'm in love with DORIS!!
« on: May 02, 2006, 11:19:15 PM »
G'day,
Can someone give me a clue as to the best type of spark plugs to use on my modified 186 (192) engine? Basically its more or less  XU1 spec.
Thanks,
Grah.
Grah
2door350
RAT 059
« Reply #1 on: May 03, 2006, 07:36:20 AM »
Try NGK 6's or 5's with a 1mm gap.  If you have a blue electronic distributor setup you can run a slightly bigger gap 1.1 to 1.5max.  I Use NGK6ES11's with my electronic setup with a 1.1 gap.  hope that helps.
Grah
« Reply #2 on: May 03, 2006, 07:56:20 PM »
Thanks mate,
That helps a lot. I have an electronic set up, so will try the NGK's.
Regards,
Grah.
Grah
Page created in 0.027 seconds with 19 queries.
