August 07, 2025, 11:48:53 AM *
Pages: 1 ... 6 7 [8]   Go Down
Author Topic: FATBOYS OLD SCHOOL UTE  (Read 97989 times)
FATBOY
« Reply #140 on: December 30, 2007, 09:59:12 PM »
some updates Started to cut out front of subframe to install vq stasteman radiator also cut off the inner lip of the chassis to give a bit more clearance ive stitched welded the gap Next i will be putting a 2mm plate over the side and welding it solid hopefully should come up nice
fatboy
fatboy
0414712441
FATBOY
« Reply #141 on: December 30, 2007, 10:02:55 PM »
started doing the brake booster mounting ill be using a vt brake booster and master cylinder trying to use the original brake pedal and mount the booster hard against the firewall
regards fatboy
fatboy
0414712441
« Reply #142 on: January 01, 2008, 11:23:28 AM »
Hey Fat,
Starting to take a little shape. I like the idea about getting more room for the rails, every little bit helps.
Jason.
FATBOY
« Reply #143 on: January 14, 2008, 12:18:10 PM »
some more updates of radiator install had to notch side of subframe to get radiator down a little bit more have boxed them and welded them up the shroud that goes over the radiator is now ready for primer more pictures soon
fatboy
0414712441
minifcvan
« Reply #144 on: January 15, 2008, 12:57:56 AM »
Hi Fat ...Can you paint it that new commodore GREEN for me? Cheers Mark
ratbox
« Reply #145 on: January 15, 2008, 05:05:55 PM »
which green mark the light or the dark the van is looking for a new colour Roll Eyes Shocked
minifcvan
« Reply #146 on: January 15, 2008, 09:12:21 PM »
TOOOOOOOOOOOOOO MANY GREENS hehehehe. the light one i think it is....
FATBOY
« Reply #147 on: January 20, 2008, 05:31:36 PM »
just another picture of the front end
regards fatboy
fatboy
0414712441
FATBOY
« Reply #148 on: January 20, 2008, 05:33:53 PM »
i made a new piece that runs along the front out of 2mm zinc anneal to help tie the two rails together in doing this i deleted the lip on the inside of the rail to match the side rails
fatboy
0414712441
FATBOY
« Reply #149 on: January 23, 2008, 11:46:44 PM »
A bit more progress tonight the commodore shroud fits and nothing fouls on the bonnet
fatboy
0414712441
« Reply #150 on: January 24, 2008, 04:56:42 PM »
All looking good Fat,
one thing, I had to do was notch the passenger side rail for more clearance for the oil filter.  While you dont have to do it (it will fit) it gives added clearance.  I use a small commodore filter.
FATBOY
« Reply #151 on: January 24, 2008, 09:15:17 PM »
Thanks for the tip ed
regards fatboy
fatboy
0414712441
FATBOY
« Reply #152 on: March 11, 2008, 08:59:34 PM »
cut these and welded them together to get the desired rake for the radiator to follow
thats it for the radiator install just got to finish the diff
regards fatboy
fatboy
0414712441
FATBOY
« Reply #153 on: March 11, 2008, 09:22:30 PM »
just some more front end pics
« Last Edit: March 11, 2008, 11:01:42 PM by stinky » Logged
fatboy
0414712441
FATBOY
« Reply #154 on: January 04, 2009, 08:49:04 PM »
Are well time to get this project back on track ek ute is finished.Have decided on a colour just got to get the ball started again
regards fatboy
fatboy
0414712441
FATBOY
« Reply #155 on: April 20, 2009, 07:09:46 PM »
Ball is finally rolling mounted the vn v8 brake booster today was a really easy job drilled a 54mm hole through the firewall and mount behind then drilled the 4 mounting holes for the booster then i cut the booster rod down then everything bolted up as per factory.
 I have been putting this job off for months but it was so easy.Wednesday night ill be into the rear cargo area and fuel tank area .Then i can mount the diff back in and the front subframe can go back on.Then i can bring it home (as long as the  ek ute sells).Might have to take it to my mums house to get it out of the way
regards fat
fatboy
0414712441
Pages: 1 ... 6 7 [8]   Go Up
