July 28, 2025, 01:03:10 PM *
Pages: 1 [2]   Go Down
Author Topic: rear main seal 308 rope.  (Read 12148 times)
FATBOY
« Reply #20 on: April 08, 2006, 01:22:18 AM »
try rocket indusrties or parramatta performance (high performance world )for your catch can
cheers fat
fatboy
0414712441
colt
« Reply #21 on: April 08, 2006, 11:52:16 AM »
Good on you, Ed. 172 hp at the wheels sounds a whole lot better than 50 or 60.
Colin
colt
FC-V8
Not enough hours in the day
« Reply #22 on: April 09, 2006, 08:15:46 AM »
     172.5 rwhp allow about 25% loss through the drive line should give you about 230 horses at the flywheel
thats not bad in anyones language.
The figure I am amazed with is the 411.7 ftlb of torque thats huge. Thats got to put a smile on your dial.
Glenn
0401-065-201
« Reply #23 on: April 09, 2006, 08:22:18 AM »
Ed,
Glenn's spot on. My trusty drag racing calculator gives an estimated ET of 14.08 seconds (weight guessed at 2800 lb's)  add a little extra time for traction issues etc and you've built yourself a high 14 second car. Pretty reasonable for an FE wagon.
At least fair competition for Leon's tar tearing blown 6 cyl ;-)
« Reply #24 on: April 10, 2006, 08:18:46 PM »
hey thanks for that guys..
unfortunately my Nats preps have been dealt a SERIOUS blow.
did a run to Evans HEad on the weekend and..
the rear main spat after I forgot to relieve the build up of pressure in the block.
i ended up dumping the gases out of the rocker breather thru two hoses to the ground.
i've narrowed down the offender as No 1 cylinder after reading the plugs  after about 2000kms.
i'm hoping to fix the seal with engine in this time. (this is why i used a neoprene seal, however I doubt a rope seal would of given out).
the excessive blow by on No 1 has me worried, I'm even debating trying to re-ring it in 3 days..
bloody thing... I knew when I had the motor out last time I should of spent a day or so more to do the lot.
Ed.
« Reply #25 on: April 10, 2006, 08:59:22 PM »
172.5/6 = 28.75 RWHP/cyl
172.5 - 28.75 = 143.75 RWHP (5 Cyl's)
Geez Ed, what's your problem? Your still have more than triple the power of those old grey smokers!!!
Shocked Shocked Shocked Shocked
Hope you make it regardless Ed.
« Reply #26 on: April 10, 2006, 09:04:14 PM »
Better pull your finger out Ed!
There are a lot of people who want to see your car at the Nats and maybe even have a chat with you  Grin
« Reply #27 on: April 10, 2006, 09:13:06 PM »
work has commenced..Grin
I mean it only used 8L of oil to Evans and back... 1L per 100kms.
in addition it has rust proofed the underbody... lol
i will be burning the candle at both ends to pull this off.
the parts have been ordered to fix the seal.
the piston willbe popped out later tonite and i will see what size it is.. there should be a stamp right?
this leaves me about a night to get it back together.. no sweat...
« Reply #28 on: April 10, 2006, 09:14:41 PM »
i meant 1L/200kms...
« Reply #29 on: April 11, 2006, 07:52:41 PM »
... managed to tear most of the motor apart..
unfor the piston ring issue will need to wait until after the Nats.  Will drive it gently down to PI to avoid too many issues.
rear main seal had turned 90 degrees again!  Angry
this makes about 2 rear mains doing that in as many weeks.
I had put permatex on the lower half of the seal this time to stop it from turning.. looks like it didnt work.
anybody have any ideas how to stop a round seal turning??
perhaps not making the seal exactly flush with the block and cap??
silastic as glue in the lower half seal??
I read some blokes pin the rope seal using a 5/16" pin.. will do this on the re-build after Nats.
ANY ideas very welcome.
« Reply #30 on: April 24, 2006, 12:10:02 PM »
So Ed, what was the final oil consumption tally for the trip?  Tongue
« Reply #31 on: April 24, 2006, 10:04:45 PM »
Heya stinky,
I've only just logged on here since the Nats,  been away on business last week etc..
Car used about 10Litres!!  was gushing like the Exxon Valdeez, but hey, it was cool I made it there.
even lost the oil cap and the windscreen wiper on route to PI.
Grin
I am pulling the motor out again this week and fixing it properly, and putting through a new set of rings hoping this will get about 18months to 2 years of crusing kms.  then I am sourcing a brand new 5.7Litre bottom end.
great to meet up at the Nats.
« Reply #32 on: May 01, 2006, 08:48:18 PM »
rear main finally fixed.
the secret ingredient is superglue (Cyanoacrylate).  this stops the seal turning.
Pages: 1 [2]   Go Up
Page created in 0.049 seconds with 21 queries.
