May 18, 2025, 08:48:10 PM *
Author Topic: wich crane hi-6 for VH commodore dizzy  (Read 5108 times)
fccool59
« on: November 25, 2005, 07:15:26 AM »
I am looking at using the crane cams fireball hi6 with the timing retard control with my electronic distributor from a vh commodore.
I looked at some in American Autos and they said the 6000-6400 was the one to use with the hei dizzy. i have noticed that on ebay they usually say the 6000-6440 is suitable for hei distributors.
The cheapest way to get one it seems will be to buy from the states of ebay but I want to be sure I am getting the rite one.
Ive noticed the crane hi 6 is becoming very popular at the drags and was wondering if any one has one on their holden 6 and what part number they got.
the usual reason for selling seems to be becuase they purchased the wrong system for their car.
« Reply #1 on: November 25, 2005, 10:06:53 AM »
Leon,
Dad has the low-end model (used to be called the XR-700) in his 179 powered FC, and has been really happy with the easy start and extra power it's had since fitted.
Charlie Boozer recently fitted the multi-spark 6000-0230 (from memory) to his grey-powered wagon.  He's reasonably happy with it, but he hasn't seen the improvement he saw in the EK (202) when he put a Commodore setup on it.  This could be due to the older coil, a less-than-perfect dissy, the lower power in the grey to begin with, or some other factor.
The 770 retails for about $160 at RS, the 6000-0230 for $260.  The lower spec one is not for use with HEI coils and requires a ballast resistor.  IIRC the higher spec version can run with either style coil, with/without ballast resistor, and the multi-spark feature really comes into its own with blended fuels (ie additives).
It would be interesting to compare all three alternatives on the same car, to really come to grips with the pros and cons of each.
Dave_EH
Keep on Holden' on
« Reply #2 on: November 28, 2005, 07:35:51 AM »
This topic sounds interesting - although I don't fully understand the ins and outs of it.
Leon or RET - if one of you has the time would you mind explaining all this more in depth.
fccool59
« Reply #3 on: November 28, 2005, 08:59:43 AM »
 this set up gives up to 12 big sparks to make sure the mixture is well and trully getting burnt, some allow you to adjust the timing from inside your car.
Some can be used in electronic ignition coversions so you can give your old grey dizzy more zap and give you a rev limit of upto 14000 rpm if you did something to the grey motor to get that sort of rpm.
benefits are higher rpm becomes not limited by the dizzy, detonation can be reduced, fuel economy may improve and power may increase.
the HI 6 set up is a box that looks like a car audio amplifier but smaller and narrower,It is mounted in your car somewere like the inside of the firewall and it wires up to your dizzy and allows you to run higher powered coils like the ps92 from crane.
The hi 6 is a common ignition in just about all motorsport.
while a commodore dizzy works well on its own this gives it bigger nuts and more brains.
« Reply #4 on: November 30, 2005, 04:56:05 AM »
... and who'd say no to that, eh?  Grin
Seriously though, check this page out.  If you hunt around you'll find the fitting instructions which have lots of detail in a PDF there as well.
PS - the one I referred to as a "6000-0230" in my previous post is actually the "3000-0231".  I haven't lost my mind, I've got it backed up on tape around here somewhere... Roll Eyes
Page created in 0.035 seconds with 20 queries.
