July 29, 2025, 05:49:15 PM *
Author Topic: heads  (Read 2073 times)
fe-ute56
« on: October 25, 2005, 06:35:31 AM »
could someone tell me if a 161 head will fit onto a 149     . i was told compresion might be a problem or lack of it . thanks danny Smiley
« Reply #1 on: October 25, 2005, 07:04:30 AM »
Head will fit OK, if you put a low compression head on an engine which previously had a high compression head, you will most certainly have less compression.  Head ismarked "H" if is a high comp head.
Dr_Terry
« Reply #2 on: October 28, 2005, 06:46:39 AM »
Hi Guys.
What Ken has said about the hi-comp & lo-comp heads is correct.
But, you will find that an original 149 head & an original 161 head are near identical, their combustion chambers are the same small kidney shaped item. As a matter of fact the early 161 heads have the same casting number. So, to answer your question it will fit  & nothing will change.
AFAIK the only change was the addition of the extra small water outlet hole, at the front of the head to suit the 161's 3-bolt thermostat housing to suit the water heated manifold hoses. The 149 had no water hole there & only 2 of the bolt holes were used.
Dr Terry.
fe-ute56
« Reply #3 on: October 30, 2005, 11:32:19 AM »
Thanks Terry thats what I wanted to hear
Cheers Danny Smiley
