« Reply #20 on: November 16, 2005, 06:42:12 AM » |
Just pop down your local metal merchant and pickup a piece of zinc annealed. Shouldn't be too much trouble to shape up, cut a rough size, make the shape, lay over the hole and trace. Cut the marked section out and weld in your new piece.
If you can, watch the Junkyard Dog 2 episode of American Hot Rod. There is a bloke doing the exact same repair on a '56 Chev, although the hole is much bigger. If you can't get hold of the episode, give us a yell and I'll burn off a DVD for you.
COL58FE
« Reply #21 on: November 16, 2005, 07:47:24 AM » |
hi stinky, is this junkyard dog a dvd at the movie hire stores,or tv type movie.if so yes please for a copy on this and any or all there episodes, C.O.D if you want. cheer's col.
COL58FE
« Reply #22 on: November 16, 2005, 07:48:54 AM » |
hi stinky, is this junkyard dog a dvd at the movie hire stores,or tv type movie.if so yes please for a copy on this and any or all there episodes, C.O.D if you want.thank's for the info too. cheer's col.
« Reply #23 on: November 16, 2005, 08:15:38 AM » |
It's on Foxtel, I missed the first ep but managed to record the 2nd, the third is on tonight. It's a "hot-rod" take on the American Chopper reality theme, following life at Boyd Coddington's rod shop. PM me you address and I'll send you a DVD. The actual tech part I am refering to is only 1-2 mins tops, but you see enough to know what to do.
fccool59
« Reply #24 on: November 16, 2005, 09:24:59 AM » |
I think I might get foxtel.
Phantom
« Reply #25 on: November 16, 2005, 09:28:05 AM » |
I'm not allowed to get Foxtel, she says i spend too much time watching tele and on the puter already. Rusty
Bogans rule
COL58FE
« Reply #26 on: December 07, 2005, 01:01:42 PM » |
g'day, well outter rh/f door done,ready for minor dent repaire's (no-rust  ). been a bit slack due to chrisie shopping, may you all have a MERRY CHRISTMAS too. more to follow next season.   cheer's col.
COL58FE
« Reply #27 on: December 27, 2005, 01:54:09 AM » |
g'day, now here's another flame'n door, there starting to getting to me so i'll stop post them for now.until i go onto something else (door jam's)  .anyway cheer's.
COL58FE
« Reply #28 on: January 26, 2006, 11:53:35 AM » |
g'day, work got rained out today so i was back at it again,what a headache this was to do. dam thing took 7hr's and 9vb's to get like this,the hardest bit was getting the masinite out from between the skin & the skeleton and i still have the other side to do too yet anyway  ,    cheer's col.
graham_fuller
Offline
« Reply #29 on: January 26, 2006, 12:31:12 PM » |
Keep up the hard work Col. It will spur us all on to greater things. Cheers, Graham
SRVLIVES
« Reply #30 on: January 29, 2006, 03:50:38 AM » |
hey Col,
How'd the wire wheel go on your panels?
The rush is on down at the shop, they're in the middle of replacing the driver's side sill and want me to come down and clean up the floor with the wire wheel... thought I might attack some panels while I'm there!
COL58FE
« Reply #31 on: January 30, 2006, 06:50:07 AM » |
SRVLIVES, they seem fine as long as you don't let the panel get to hot.on the outside skin i used a linsish disc then the wire wheel to get the rid of any left over's and hand sanded them to smooth it all up like NEW again. cheer's col.
SRVLIVES
« Reply #32 on: January 30, 2006, 06:59:55 AM » |
hey Col, Thanks for the reply. Went down to the shop this morning and cleaned up the floor with the wire brush, pretty clean. Driver's side front floorpan needs replacing (I already have a new one to go in) rear needs no repairs at all. Sill has been taken off, there is a small amount of rust at the bottom of the A pillar, but the inner sills are bewdiful!  Used the wire brush in the drill to attack the front of the bonnet where the letters were, more out of curiosity than anything else, had almost no effect at all!... The paint on this thing must be 3mm thick! Time for Plan B......
« Reply #33 on: January 30, 2006, 07:55:53 AM » |
SRV if you wanna see the paint come off in a hurry, get a cup brush for your angle grinder  . Start slowly though.
SRVLIVES
« Reply #34 on: January 30, 2006, 09:41:12 AM » |
You mean one of these...  ... tried that. Maybe it needed some edges to 'bite' into?
COL58FE
« Reply #35 on: January 31, 2006, 07:40:19 AM » |
SRV, ya have to use a linish/sanding disc first mate then the wire wheel is in it's glory. cheer's col.
