May 19, 2025, 03:50:22 AM *
Author Topic: HR Brakes  (Read 2320 times)
cruiser056
cruisin to the rock and roll
« on: September 21, 2005, 07:04:07 AM »
Hi all,
         I 've got a HR front and rear end in my FE with new brakes all round.  Also a newly reco'd brake booster.
The problem is when the engine is running the brakes hold on, but when the engine is off the brakes are off.  Obviously a booster problem, but can anyone shed some light on my problem, please?
Michael
FCwagon
« Reply #1 on: September 21, 2005, 07:54:12 PM »
Michael,
Are you using a disc brake type master and/or have you removed the non return valve from the old master cylinder?
If not, that could cause your problem.
Leigh
Red & white is alright
cruiser056
« Reply #2 on: September 21, 2005, 08:17:17 PM »
Leigh,
         I believe it is the same master cylinder that was on the car when it had the drum brakes.  How do you remove the non return valve?
Michael
nicko
« Reply #3 on: September 21, 2005, 08:36:16 PM »
you remove master cylinder and pull it apart ,in bottom there is a  thin washer take this out and put cylinder back together(would be a good time to put new rubber kit in)and bobs your uncle "working brakes"
cruiser056
« Reply #4 on: September 21, 2005, 08:55:47 PM »
Nicko,
          Thanks for the info, will do, let you know how i get on.
Michael
cruiser056
« Reply #5 on: September 22, 2005, 04:08:14 AM »
Nicko & Leigh
                        I pulled the master cylinder apart and removed the part you suggested, problem solved.  The master cylinder looks as though it was reco'd not long ago everything inside looked like new.
Thanks for the help, greatly appreciated.
Michael
Page created in 0.043 seconds with 19 queries.
