July 27, 2025, 05:30:59 PM *
Author Topic: Hi Tech Laser Bump Sreer Gauge  (Read 2217 times)
sgo
« on: September 18, 2005, 04:52:16 AM »
For about $12 at your local electronics store you can get a "Laser Pointer" and with a rubber band, some tape and a sheet of chip-board you can have your very own bump-steer gauge.
Perfect for checking that rack installation!
If all is well the dots you mark, through the suspension travel, should all be in a straight line.
« Reply #1 on: September 19, 2005, 10:28:24 PM »
Hey SGO,
that's a neat idea.
the set up you have there looks interesting too
Dr_Terry
« Reply #2 on: September 20, 2005, 11:15:41 AM »
Hi sgo.
The set-up you have there is quite good, but you mention that all the dots should be in a straight line.
The line should also be dead vertical. If the line was straight but at say a 20 degree angle you would still have bad bump steer.
It's actually probably MORE important that it be near vertical than actualll dead straight.
Dr Terry.
sgo
« Reply #3 on: September 21, 2005, 07:45:52 PM »
Thanks Dr Terry,
So if the line is at an angle, with the ride height point in the centre, then you would have toe-in above the centre point and toe-out below the centre point, for example?  ?  ?
Dr_Terry
« Reply #4 on: September 22, 2005, 06:01:08 AM »
Hi sgo.
Yes, exactly, you do not want the line to be anything other than vertical, otherwise you will have toe variation on suspension travel, which of course is what bump-steer is.
Dr Terry.
Page created in 0.047 seconds with 19 queries.
