May 19, 2025, 05:28:43 AM *
Author Topic: Auto Safety Ignition Cut-out  (Read 4224 times)
« on: September 14, 2005, 08:44:18 AM »
Finally wiring up the interior, but I am a little confused as to how to wire up the ignition cut-out for the auto.
The kit comes with a wire for the job, but it is not in the loom, just seperate.
I am using a B&M Quick silver shifter with a micro-switch that does the cutting out duties.
as always, any help appreciated.
fc_1958
FC5959
« Reply #1 on: September 14, 2005, 09:39:06 AM »
Stinky
Give us some more info - is this the auto behind a grey?
Or is it a V6 conversion?
Are there 2 leads from the micro switch or does the switch ground when in Park or neutral?
Any idea of the micro switch rating?
Andrew
Andrew..... AKA   FB 60 on the "other" forum.
« Reply #2 on: September 14, 2005, 12:01:07 PM »
202/Trimatic using a pre-made Airide wiring kit.
The microswitch has two terminals, not sure whether it is set to be open or closed when in gear though and I have no idea of the rating, sorry.
fc_1958
FC5959
« Reply #3 on: September 14, 2005, 08:15:40 PM »
Stinky
You will find that more than likely the contacts will be closed when in park or neutral.
If you do not have a multi meter test using some wires, a 12v globe and battery.
Assuming the above test verifies that the switch closes in N and P, there are 2 ways to wire - the most common is to put the gear switch in series with the starter solenoid. - Disconnect the start wire from the starter solenoid, connect to one terminal of the gear switch and connect the other side of the switch to the starter. (Do this if the wire supplied with the switch is of a simmular gauge as the start wire this will indicate that the switch can take the current).
The other method is to use a relay ( headlight variety will be good enough). Use this if the wire supplied with the gear switch is smaller in diameter then the start wire. Connect one side of relay coil to accessory power and the other to the gear switch, earth second terminal from gear switch. Connect the start wire to common contact of relay and run a wire from the normally closed contact to the starter solenoid.
Good Luck  Smiley
Andrew
« Last Edit: September 14, 2005, 08:17:01 PM by fc_1958 » Logged
smithy
yeah its purple !
« Reply #4 on: September 14, 2005, 09:13:02 PM »
hi stinky, in a pinch you could always give glenn from airride a call, i used one of his kits to rewire my car and had to call him once or twice and he was always very helpfull and happy to answer my questions.
dean
« Reply #5 on: September 14, 2005, 09:45:41 PM »
Thanks for the tips Andrew.
Dean, whilst Glenn at Airide is very helpful and polite, it is next to impossible to contact him. After a couple of emails, a lot of time on the phone with the number ringing out and even two faxes, I finally caught him a few days ago.
It is so much easier and quicker to post here, we should count ourselves lucky for this excellent resource. In less than 1 hour I had a response!
FC-V8
Not enough hours in the day
« Reply #6 on: September 14, 2005, 10:29:57 PM »
Glenn
         When I wired up my B&M shifter I found the wire from the ignition to the starter solenoid cut & joined both other wires to each end which then run over the tunnel to the shifter & join both to the 2 teminals on the cut out switch. The switch allows the car to start when the switch is closed( toggle pushed in). My wagon can only start in park but you can wire it up to start in neutral also but I could be bothered mucking around with it.
Glenn
« Last Edit: September 14, 2005, 10:31:13 PM by GLENN » Logged
0401-065-201
smithy
yeah its purple !
« Reply #7 on: September 14, 2005, 11:18:34 PM »
fair enough stinky, i would have to agree with you he is a hard man to catch. it was alot easier a couple of years ago before the business really took off. Wink
« Reply #8 on: October 20, 2005, 10:27:58 AM »
Stinky
Good Luck  Smiley
Andrew
Andrew, I tried the relay and it does not work, I can hear the relay click, I have tried two relays so I know they are not duds.
I think the problem is that when using accesory power, the power gets dropped when the key turns to the START position, thus switching the relay off.
Would that be right?
I guess I need to forget the relay and run some thick guage wire down to the micro-switch now, unless there is a clever way to keep the relay powered up.
« Reply #9 on: December 31, 2005, 11:17:55 AM »
Got back to this today  Roll Eyes
I ended up wiring up the switch on the shifter in series (?) with the ignition wire, did a couple of test starts with no puffs of smoke, sizzling noises or anything getting hot  Grin
I guess that means it's OK.
fc_1958
FC5959
« Reply #10 on: January 01, 2006, 07:53:22 AM »
Hey Stinky
I would say the relay is good enough to take the amps.
Sorry I did not see your Sept 14 posting. The starting current could have ben taken straight from the battery using an in line fuse, or from within the replacement wiring harness fuse box. I believe there is an 'always positive' some where  - used to drive parking lights, memory for post FC type wireless(I belive they call them CD players. Grin) and other modern electrical type stuff Grin Grin
However as it works -don't fix it.Cheesy
Andrew
« Last Edit: January 01, 2006, 07:55:13 AM by fc_1958 » Logged
Page created in 0.038 seconds with 21 queries.
