May 19, 2025, 03:41:27 AM *
Author Topic: Light bulb paint.  (Read 12229 times)
« on: August 20, 2005, 02:48:43 AM »
Hi,
Was wondering if anybody had any ideas about how to paint a dual filament globe orange?
reason is I am using a dual filament globe as an indicator/reverse light and wish to have a clear lens rather than amber.
to overcome this i thought I could paint the bulb?
any ideas on a hi temp dye?
earlyholdenfan
« Reply #1 on: August 20, 2005, 03:02:11 AM »
Check out the craft shops, or lighting retailers, there is a transparent paint that is used to paint light globes (to be sold at markets) and if it can withstand the 60 - 100 watt bulb temp it should be good for the lamps!
or why not replace them with LED amber globes from
http://www.led340.com/
or try this guy for orange bulbs with the correct fitting
http://www.classicandvintagebulbs.com/
Hope this helps a little
Matt
Wouldnt your reverse lights also be amber in that case?
« Reply #2 on: August 20, 2005, 03:24:26 AM »
Hey Matt,
that helps alot, i did a quick google on glass paint for bulbs as u suggested and it seems easy to get.. and cheap!
ive already replaced my stop lamps with LEDs, but im not sure if they come in orange to suit a dual filament.
hadnt thought to look in vintage bulbs, wasnt sure if dual filament orange globes are in much demand.
I can live with orange reverse lights more than amber lenses. :-)
the EH has orange reverse lamps and it is very bright.
thanks for your help Smiley
Jockster
« Reply #3 on: August 20, 2005, 07:44:13 AM »
You can buy amber dual filament globes from any Repco store, they are conventional globes not leds and cost the same as an ordinary globe
Jock
blacky
« Reply #4 on: August 20, 2005, 09:51:12 PM »
 You need to check that the little pins that hold the globe into the globeholder are right when trying to fit orange globes where clear ones used to live - I got caught with that on my EK , the orange globes have the pins offset a little , i.e. not 180 degrees apart when looking from the contact end.
Perhaps there is someone making them to retrofit the earlier models , I was using commodore globes and they wouldnt fit.
Jockster
« Reply #5 on: August 21, 2005, 02:46:44 AM »
Some of the globes have an odd offset for commodores etc, but the Repco ones have the standard offset pin common to most cars.
Jock
« Reply #6 on: August 21, 2005, 06:07:46 AM »
I used the Commo offset globes and ground one pin off. Been in the car for over 2 years now without a problem
If they ever do fail I will get some Repco ones though.
smithy
yeah its purple !
« Reply #7 on: August 21, 2005, 06:36:31 AM »
hi ed, i used some light bulb paint for all my dash globes, my fiance uses it to paint glass arty things.
i painted the whole instrument lights including speedo and aftermarket gauges blue. gives off a realy nice glow and very cheap to do. and the blinker indicating lights are a purple (rusty one for you Smiley ) the only problem is they smoke for a couple of minutes when first turned on until the paint cures, all her artworks get baked in a oven to set the paint. before being sold
it can be bought from any good art store
dean
Jockster
« Reply #8 on: August 21, 2005, 11:25:08 AM »
Repco also sell coloured....condoms.... for dash bulbs, you just pull it over the globe, turn it on and allow it to heat and cure, they come in a variety of colours
Jock
Dr_Terry
« Reply #9 on: August 21, 2005, 07:19:04 PM »
Hi Guys.
Getting back to the original post. Why do you need dual filament globes.
Doesn't your blinker switch allow you to run the blinker/reverse light from 1 filament like the factory set-up.
Also there are 2 types of dual filament globes. The normal 21/5w just like a standard stop/tail or front parker/blinker, also there is a 21/21W which is used in situations like yours where you need both the blinker & reverse to be bright. These are more difficult to find, but they're the ones you need, I think.
Dr Terry.
« Reply #10 on: August 22, 2005, 08:32:32 PM »
Hello,
thx for the replies... interesting!
ok I am running Dual filament globes simply beacuse a VB-VK indicator switch does not support standard indicators (not that I could work out anyway).
and it was easier to run dual filament globes for the reverse than to try nut out how they managed to use a single filament globe.
Hope this makes sense...
looks like 21/21 globes are the go then... I had wondered why my reverse lights were so dim....
