May 25, 2025, 11:18:44 PM *
Author Topic: quarter vent reassembly  (Read 2463 times)
Jonno
« on: July 24, 2005, 09:13:07 AM »
Just wondering is there any trick to replacing glass in the quarter vents? I bought some rubber strip from Scotts Old Auto rubber (I assume this was a generic type) and have spent all day trying to put the glass back in to the re-chromed channels with this rubber. Apart from requiring more force than I can supply, the rubber tears every time where the channel cuts into it.
The rubber I have is 1.5mm thickness so I assume I need something a bit thinner. Anyone have any recommended suppliers (i.e. stuff that works for FE/FC)?
thanks, jonno
Cottles Bridge, VIC
cer444
138 "Big Block" Grey
« Reply #1 on: July 25, 2005, 04:08:02 AM »
Take it down to your local windscreen bloke and he can glue them in with a product called "Sikaflex".
You can buy this at a good auto parts store but in comes in a cartridge and you will pay around $20 a tube
Sikaflex make a few product so make sure you get the one for gluing glass.
Jonno
« Reply #2 on: July 25, 2005, 05:25:10 AM »
so rubber is not required if you use this stuff?
Cottles Bridge, VIC
« Reply #3 on: July 25, 2005, 05:32:24 AM »
Jonno,
The Sikaflex product range includes a window sealant which means that the rubber is not really required. Just put a reasonable bead off Sikaflex in the channel and push the glass into place. For a neat finish the excess can be wiped off with thinners.
Here's some info on Sikaflex products.
http://www.sika.com.au/home/cmi/sikainside/automotiveline/products/windshield/index.htm
Any auto paint supplier will stock the product.
« Last Edit: July 25, 2005, 05:33:21 AM by craiga » Logged
Jonno
« Reply #4 on: July 25, 2005, 06:37:43 AM »
sounds cool...thanks guys
Jonno Grin
Cottles Bridge, VIC
