August 29, 2025, 07:54:19 AM *
Author Topic: HR front end - ball joints, springs, shocks  (Read 2417 times)
Dave_EH
Keep on Holden' on
« on: June 13, 2005, 09:31:54 AM »
G'day,
I have found a shop that can supply upper and lower ball joints and new lowered springs for my HR front for $240 which is well below the price of most other places I've tried.
However, the shop is located on the Sunshine coast (QLD) and I am in Brisbane and my car is not on the road.
Bearing in mind I haven't ever played with springs before, should I buy the gear and get it installed by someone in Brisbane (and never learn how to do it myself), or try and do it myself - will I need a spring compressor and ball joint cracker?  The bloke up the coast quoted $150 including alignment.  How hard is it?
My shocks (pedders) are also ten years old, and while have only travelled 14 000miles have been sitting static for a long while - should I replace them at the same time?
Can someone recommend a brand of shocks (heavy duty I guess) or is reconditioning an option?
« Reply #1 on: June 13, 2005, 10:57:34 AM »
Do it yourself!
You'll save money, have satisfaction and pride in the job plus have better understanding of how you car works.
It ain't brain surgery and with a good shop manual and access to this board, you can't go too far wrong.
If the springs are lowered a fair amount, you may not need a compressor to get them in. I didn't on my HR front end.
Ball joints, depending on the type you purchased, you need to grind off the blind rivets holding the old ones on and just bolt the new ones up.
I stand to be corrected on the above, but that's how I've done it on my car.
« Last Edit: June 13, 2005, 10:58:23 AM by stinky » Logged
Sarge
« Reply #2 on: June 13, 2005, 07:51:25 PM »
        Give a crack as Glen said, If you get stuck just sing out. There are plenty of us her to help you out.  You dont need to be a rocket scientist.
Sarge
« Last Edit: June 13, 2005, 07:52:04 PM by Sarge » Logged
        0421 165 351
Dave_EH
Keep on Holden' on
« Reply #3 on: June 13, 2005, 11:02:08 PM »
Thanks fellas,
 I'll order the goods and have a go at the end of the month after exams.  I've got a mate keen to help, and I've got the workshop manual so we should give it a good crack.
Sarge
« Reply #4 on: June 14, 2005, 02:58:51 AM »
       Great to hear this way you should save a few dollars and its the best way to learn more about your car.
Sarge
        0421 165 351
SRVLIVES
« Reply #5 on: June 14, 2005, 04:15:22 AM »
While it's true you may not need a spring compressor to put the new lower springs in, ALWAYS USE ONE TO TAKE THEM OUT!!!
A spring suddenly released from it's confines will not treat you kindly.
Page created in 0.037 seconds with 22 queries.
