June 18, 2025, 05:37:03 AM *
Author Topic: spray gun problem  (Read 2924 times)
knickers
« on: June 07, 2005, 04:01:22 AM »
We have the ute in most parts ready for undercoating but on a dummy run the spray gun is 'pulsating' - have cleaned the gun by running thinners thru but still same - although not quite as bad - anyone any ideas on what could be the likley cause
Cheers Nickers
« Reply #1 on: June 07, 2005, 04:24:51 AM »
I'd be cleaning the gun again thoroughly, maybe even pulling it apart to do so.
I had the same problem on my "junk" gun that use for around the house painting and it was full of crud.
« Reply #2 on: June 07, 2005, 04:26:48 AM »
Nickers,
check to see there are no air leaks.
take the spray horns off the front of gun,
take out the fluid tip.
make sure the fluid tip is tight down with a good seal behind it,  should have a nice plastic o-ring in good condition. if not, replace it... this is most likely your source of air causing flutter.
I also put just one drop of oil where the fluid needle enters the back of the gun housing.
I find this stops the fluttering, running thinners doesnt show up the flutter either, only when u put the heavier paint in.
hawk
« Reply #3 on: June 07, 2005, 04:57:13 AM »
Nickers also check small on top of gun lid is not blocked as is a breather hole.......
knickers
« Reply #4 on: June 07, 2005, 05:01:26 AM »
Thanx guys
The gun - a 770 - is new & only used once before so there shouldn't be any faulty parts ?
I've got line pressure set at 55 psi.
Ed do you mean a drop of oil at the end where the adj nut is or at the end where the cap is
« Reply #5 on: June 07, 2005, 05:06:55 AM »
Thanx guys
on my gravity feed gun follow the fluid needle until you see it enter the gun body. you will see a little brass nut with holes in it.  that it where i put a drop of oil.
i put vaseline or white light grease on the spring under the adjuster at the back of gun.
this jut makes it operate smoothly
Page created in 0.038 seconds with 21 queries.
