September 03, 2025, 11:12:56 AM *
Author Topic: fe hotrods not so cool ride!!!  (Read 7226 times)
fe hotrod
« on: May 29, 2005, 04:55:57 AM »
Thought i would post some pics of a fe ute i recently bought,not to sure if i am going to wreck it or strip it right down and restore it??have a look and let me know what you all think,it has got bad rust in the floor pans and sills,although theres no rust in the windscreen cowl,subframe doglegs,bottom of the rear quarters,sort of not sure what to do???i would hate to see it go to the tip!!!
« Last Edit: May 29, 2005, 04:58:14 AM by fe_hotrod » Logged
fe hotrod
« Reply #1 on: May 29, 2005, 04:59:34 AM »
fe hotrod
« Reply #2 on: May 29, 2005, 05:00:45 AM »
fe hotrod
« Reply #3 on: May 29, 2005, 05:03:33 AM »
REDMR2RED
FC Ute's d'best
« Reply #4 on: May 29, 2005, 05:39:40 AM »
Got a lot of work ahead of you there.  There's also lots missing from the photo, engine, steering wheel, etc. Do you have all the missing bits? or is that what you bought, just the body.
Too good to send to the tip tho.
My 2 cents, Kevin
REDMR2RED
1959 FC Holden Ute
fe hotrod
« Reply #5 on: May 29, 2005, 05:59:44 AM »
 ;)kevin, i have most the parts that are missing ,the motor and box are still in her,i have a tail gate,spare wheel door, and most of the missing bits,mostly bolt on stuff!!!!mmmmmmmto do or not to do???
FC0058
Jim Altmann
« Reply #6 on: May 29, 2005, 08:37:04 AM »
If it is as good as you say, I would strip it down and rebuild. But I am not the one with the work ahead of me.
Cheers Jim
« Reply #7 on: May 29, 2005, 08:38:48 AM »
As the little blond girl on the ad says......CHOP IT!
Drop that roof. What do you have to lose.  Grin
Spinner
« Reply #8 on: May 29, 2005, 09:41:45 AM »
Looking at it, I reckon that you should fix it.  It'll make a nice work car so you can keep the sedan special.
TAYZ
« Reply #9 on: May 29, 2005, 09:50:54 AM »
jamie,
           That ute looks like an excellent project.  Dont scrap it, take your time and do it up, at the end you will reap all the rewards and have an excellent ute to boot!!!!
                                                   TAYZ
HARKO
« Reply #10 on: May 29, 2005, 11:08:36 AM »
I dont think you'll go ahead with it , Asking the question should I ? has "Its a lot of time n money & Im not that keen" written all over it .
HARKO
« Reply #11 on: May 29, 2005, 11:13:55 AM »
But on that note , I would suggest sandblasting it , It will look a million bucks (sparking enthusiasm) be cleaner for repairs and repair size becomes visable, better resale etc etc
stevefcvan
« Reply #12 on: May 29, 2005, 07:28:29 PM »
         gee that brings back a lot of memorys of my first ute that i bought. it was a fe that nice glowing gray with only a bit of surface rust over it and the floor was rusted out like yours. i ended up swaping to the spray painter that work for my father inlaw to paint my lj torana that we had just fineshed  at the time,   as i did not have any were to store it back thet,   wish i had the area i have to day as it would look like a wrecking yard.           (i suppose it looks like it now)
FATBOY
« Reply #13 on: May 30, 2005, 12:10:55 AM »
if you dont want to go a head with it i will gladly take it off your hands or swap you my fe wagon
cheers fat
fatboy
0414712441
Al
I love FC Ute's!
« Reply #14 on: May 30, 2005, 07:37:16 AM »
Hey you gota start with something and somewere. That'l keep you off the steets for a while Good luck with the resto.you'l do it just take your time
   Cheers Al
See ya
Al
hrpanoben
« Reply #15 on: May 31, 2005, 06:14:23 PM »
Hi,
This has rat rod written all over it!!!
Ben.
« Reply #16 on: May 31, 2005, 08:34:41 PM »
turn it into an experiment into radical custom bodywork as suggested above.
failing that.. turn it into a cool trailer.
fe hotrod
« Reply #17 on: May 31, 2005, 11:56:19 PM »
 ;)thanks for the encoragement fellas,im going to strip it repair the rust in the floors and sills remove the subframe and put her on her side,after looking at how streetneat has done his rear floor in his fc ute,it doesnt look that bad after all,maybe a roof chop its a lot easier with a ute thats for sure!!ive been toying with the idea of suicide doors(once fatboy works out how to do it on an early holden!!)matt purple paint with some scallops make it real low,red rims in that true rat style no caps of course,then i will have a real rat fe ute,big project,although i,ve got the time and the money,and a heap of motivation which i find you can get easily from the guys on this site,so here goes im out to the garage to make a start!!!!!!cheers jamie
Page created in 0.044 seconds with 20 queries.
