June 20, 2025, 04:11:46 AM *
Author Topic: Help with Holly installation  (Read 1975 times)
Dave_EH
Keep on Holden' on
« on: April 14, 2005, 12:27:52 AM »
Hi,
I've borrowed a Holly off a mate while my twins are restored, and need a few tips.  See photo below.
On his 186 with a rocker cover with two holes it was set up as follows:
1 - to rocker cover without a pcv valve
2 - to second rocker cover hole with pcv valve
3 - to brake booster.
My rocker cover only has one hole.
a) should I run outlet 1 (from filter) to the rocker cover and plug up outlet 2?
b) should I plug up 1 and run outlet 2 to a pcv valve in the rocker cover?
c) should I plug up 3 and run the booster to 2 and run 1 to the rocker cover without a pcv?
any other suggestions?
sorry about the size of the photo
« Reply #1 on: April 14, 2005, 06:54:50 AM »
Hi Dave,
1. Block Off.
2. PCV
3. Brake Booster.
Regards ACE  Cool
Dave_EH
Keep on Holden' on
« Reply #2 on: April 14, 2005, 10:45:12 AM »
Thanks Ace
Dave Grin
NO NAME
« Reply #3 on: April 15, 2005, 12:34:07 PM »
ace that is exactly how my car was but I am now looking for a better way, probably just with a breather or oil catch can.
Dr_Terry
« Reply #4 on: April 17, 2005, 08:49:29 PM »
Hi Guys.
Do exactly what ACE has said, but don't forget to run a vented oil cap.
When Holden used the rocker cover with 2 holes they had a sealed oil cap. If you only have a 1 hole cover you must use a vented cap.
If the engine is a bit sad & has excessive blow-by, you may have you get a 2 hole cover &/or a vented catch can.
Dr Terry.
Dave_EH
Keep on Holden' on
« Reply #5 on: April 19, 2005, 10:21:29 AM »
Thanks Dr Terry, much appreciated!
Page created in 0.042 seconds with 19 queries.
