June 03, 2025, 11:52:09 PM *
Author Topic: Engine Block painting  (Read 5868 times)
« on: October 25, 2004, 11:12:44 PM »
Does anyone have a sure fire way to paint an engine block and keep it painted?
My engine was done in two-pack last time and has flaked off in numerous places.
The current plan is to remove all of the current paint and debur the block using a combo of stone and metal bits. So far this looks to be a better surface for the paint to adhere. Then I was going to hit it with a couple of can of VHT Paint.
I did look at the POR product, but the Ford Mid Blue that they had was quite bland and nothing like the Mid Blue you see elsewhere.
« Reply #1 on: October 25, 2004, 11:30:06 PM »
Stinky,
I reckon you had oil on the block still, that's why the 2 pack came off. I've seen plenty of engines painted in two pack, and it sticks really well and holds up to the heat OK.
fccool59
« Reply #2 on: October 31, 2004, 05:41:02 AM »
although the vht heat resistant paint is probably purpose made, 2K usually works better on engines, better finnish, more heat resistant and heaps more durable when most degreasers are applied. some chemicals take half of the spray can paint of when you clean your motor.
PanelAndSpray
grind bashbash grind pshhh-pshhh finished!!!
« Reply #3 on: January 26, 2005, 08:02:09 AM »
2Pac is 2Pac, a bloody awesome paint product that was designed and developed to work on ALL metal surfaces and others.  If 2Pac isn't sticking to your engine block then you, (or your contractor), didn't clean it properly.  Before I clean a panel for painting, I consider what elements this panel has been exposed to. This helps me determine what cleaning processes are required for the panel, (object).  There are only two forms of cleaning when considering paint, they are Mechanical in the first instance and Chemical in the second. Painting always requires BOTH.  Mechanical involves sanding etc, chemical is self explanatory.
Your engine block has been exposed to ALL of the nastiest agents out there to kill paint, so you MUST mechanically clean your metal surfaces first with either sandpaper, die-grinder, D.A., Angle Grinder etc, then acid wash your block with a mild degreaser agent then shampoo, YES I SAID SHAMPOO, the block off with a good quality car wash, then dry the block off ENTIRELY. That means DRY.
Now comes the interesting bit, you need to apply a good quality DEOXIDINE solution to the block, this is a metal treatment product and is comprised of Phosphoric Acid. Generally, the mixture as per instructions is 50:1 water to Deoxidine but I always go for no more than 25:1.  Deoxidine removes heat and rust scale, other acids and oils and more, refer to this link for more info. http://www.chemicalcontacts.co.za/acid.htm
Deoxidine must be applied in a unique manner and preferably with scotchbrite pads (green). Apply with scothbrite and vigorous rubbing in small areas NOT WHOLE BLOCK AT ONCE. then wash off that area with PLAIN CLEAN WATER, then DRY with Clean Dry Rag and Compressed air.  If done correctly, you will notice a blue to yellow tinge to the metal surface.  Do this untill the block is done entirely. In other words it is a two step process per area that is treated.
Now that you have completed these steps, you must now protect the metal surface from future contaminates, (i.e oxides), I always use an etch primer in this instance, UNLESS USING A PRODUCT THAT STIPULATES NOT DOING SO. This will result in a metal surface that will remain oxide free and ready for primer/paint in the very NEAR future, days not weeks fella's.
And as always, I expect you shall always use the correct PPE whilst doing the job yeah. This is a definitive and exhaustive explanation on how to clean metal for paint.  I can go on but this will suffice for all general AUTOMOTIVE uses only.  Spread the word.
Regards,
PanelAndPaint.
Grind Grind BashBashBash Pshhh-Pshhh.....Finished!!! :-)
Fast_Eddie
« Reply #4 on: January 26, 2005, 08:24:52 AM »
Paint & Panel,
That sounds like an expensive and drawn out process. I'd hate to have to pay your bills.  Wink
Will air dry enamel work?
If so, is it suitable to apply over the etch primer?
PanelAndSpray
« Reply #5 on: January 26, 2005, 08:42:34 AM »
G'day Fast Eddie, not expensive, just time consuming if your doing it yourself and yes air-dry enamel will work but watch out for discolouring of the paint as not all air-dry enamels can handle 350+ degs C of temp.  This is commonly referred to as paint yellowing.
NICE TRY!!
« Reply #6 on: January 26, 2005, 12:32:08 PM »
Too late for me now, a can of VHT did the job, after a bit of work with a carbide bit, stone bit, various wire wheels (including one on an angle grinder) and a little backyard sandblasting. A good wipe down with wax and grease remover and sprayed.
All done while crossing my fingers  Grin
NO NAME
« Reply #7 on: January 26, 2005, 09:23:59 PM »
back yard sandblastig, yikes, I hope you had everything sealed off good.
« Reply #8 on: January 26, 2005, 10:38:12 PM »
So do I!  Cheesy
I used gaffer tape rather than ordinary masking tape as it sticks like the proverbial to a blanket.
Page created in 0.042 seconds with 21 queries.
