July 07, 2025, 03:14:36 AM *
Author Topic: REAR WHEEL TUBS  (Read 3940 times)
FATBOY
« on: October 13, 2004, 09:03:17 AM »
has any body done wheel tubs if so how did they go with moving the spring hangers and the engineer i only want to make the wheel tubs to suit 265 tyres
any help would be great
cheers fatboy
fatboy
0414712441
« Reply #1 on: October 13, 2004, 08:19:07 PM »
Fatboy,
I've thought about this a great deal...
1st you cant move your spring hangers as they are fitted to the subframe.. you cant put full tubs into a FE/FC because cutting the subframe is a no no (In NSW anyway).. unless you want to register your car as an ICV.. and pass all current ADR's... so mini tubs will be the easiest.
essentially you would have to unstitch your inner guards (you can see the seam if u stick your head up in there - I was going to cut about 5mm inboard of this).
then cut it out and go right back to the subframe (gaining about half an inch or so).
make up a panel by carefully marking out the gaping void left by removing the wheel arch.
tack in place and make a half moon-ish shaped inner panel.
keep tacking until it's in.
PRPOPIG (Brett) can prolly give u better pointers, as his ute has them.
Harko is full of wild ideas too.
The reason I didnt do it was...
can already fit 225's with gobs of clearance.
would of had to re-do my rear seat belts
would have had to spend lots of time thinking about my rear seat
lost alot of luggage space
fatter tyres were more expensive
I think I will enjoy my wagon as is... these are future mods for me placed on the back burner.
propig2003
« Reply #2 on: December 01, 2004, 12:20:18 PM »
fatboy, brett here, in regards to tubs, i moved the rails in around 100mm each side along with a narrowed 9''.
springhangers were moved with the chassis rails as if in the original possi. this allows me to run 305x50x15.
if running mini tubs, you wont have to move the hangers as they remain in their orig place. they would only have to be moved if going larger tubs.
hope this helps
brett
(propig)
FATBOY
« Reply #3 on: December 01, 2004, 12:38:50 PM »
how did your engineer like it
cheers fatboy
fatboy
0414712441
56aussie
« Reply #4 on: December 06, 2004, 11:13:34 AM »
Not wanting to hijack, Fatboy,  but i have a few related questions.
Does anyone here have a measurement of just how much a diff moves sideways?
So how far can you bring the wheels inwards before you need mini tubs?
Is there a tyre clearance regulation measurement?
Mine have about 70mm at the moment. I have 205/60/13s.
They just barely touch the outer guards now.
I  think i can fit 245/50/14s if i reduce the inner clearance to about 25-30 mm.
Mini tubs sounds like a lot of work to go to 265s.
Tony
All of my tools are hammers,
except the chisels,
they are screwdrivers.
